A project log for (8:1) 3D Printed Planetary Gear Actuator Module
3d printed 8:1 planetary gear ratio actuator module with VESC firmware based circular motor driver
You can check it here;
https://ieeexplore.ieee.org/document/8957033
Yes, delete it Cancel
