Stuart Conner's Mini-Cortex board build
Stuart Conner's Mini-Cortex design, slightly modified.
Uses the TMS9995 processor.
Modifications:
  • Low-height crystal is less vulnerable to knocks
  • Omit video module socket. C10 and C15 for now
  • Omit CF card for now
  • Omit memory mapper
CORTEX-edited-EQN.txt
Edited to a form to aid my understanding. Untested, unverified.
plain - 1.50 kB - 04/16/2022 at 23:25
Download
CORTEX-EQN.txt
Stuart's logic equations. They work, but use the "dual" of what I would expect, so I found them hard to follow.
plain - 746.00 bytes - 04/16/2022 at 23:03
Download
CORTEX.JED
JEDEC file for programming the GAL. Generated from Stuart's equations.
jed - 3.11 kB - 04/16/2022 at 22:59
Download
Mini Cortex Schematic (with latest GAL equations) (V2).pdf
Mini Cortex schematic.
Adobe Portable Document Format - 69.28 kB - 04/11/2020 at 23:30
Preview
  • Construction
    Keith04/27/2022 at 00:29 0 comments
    2022-04-25
    Soldered on the Mini Cortex board:
    • U1 TMS9995 socket
    • U3 74LS14
    • U6 74LS688
    • U9 omit FTDI module and use FTDI cable instead
    • U10 74LS259
    • U12 74LS74
    • U13 74LS112
    • U14 74LS138
    2022-09-30
    • U2 memory mapper socket, DIP40.
    • U4 32K ROM socket, DIP28.
    • U5 512K RAM socket, DIP32.
    • U8 9902ANL, DIP18.
    • U11, DIP24 socket for 22V10.
    • X1 crystal, 12 MHz or near.
    • J3 for FTDI cable.
    2022-10-02
    • R3 and R13 (LED resistors)
    2022-10-16
    • Program 32K EEPROM AT28C256 with firmware.
    • Program U11 PAL ATF22V10C.
    202?-??-??
    • Find and fit TMS9902 serial chip
    To do:
    • Test BASIC operation
    • Find and fit memory mapper chip
    • Fit compact flash
  • Project Log
    Keith09/28/2019 at 22:53 0 comments
    2019-09-23
    Ordered TMS9995, TIM9904 and TMS9929A from Chinese source.
    TMS9929A is a PAL video chip, but might be useful on a simple video display board. Might make one board support multiple chips e.g. a 6847 as well.
    2019-10-09
    TMS9995 and TIM9904 chips arrive.
View all 2 project logs
