The Zilog ZS180 seems to be the last member of the 64180 family in active production.
For 33MHz clock max:
3 clocks per memory cycle = 11 MHz cycle rate.
3 clocks per instruction = 11 MHz instruction rate (one opcode).
6 clocks per instruction = 5.5 MHz instruction rate (one opcode, one data byte).
32 MHz would be more convenient , as the STEbus needs a 16 MHz system clock.
I recently bought eight Z180 chips for £5. Rated at 8 MHz so only twice as fast as a 4 MHz Z80, but will be okay for most work.
The Z180 would be useful for applications that would benefit from 1 megabyte of memory space, such as CP/M. However, I would use my PC for development work and Z80 systems as targets to run small applications. Therefore it might be more useful to develop a faster Z80 system than a larger Z180 system.
I considered using the existing SC130 board to avoid a lot of hand-wiring address, data and control buses. There is not much complicated going on there. The firmware is working with an overclocked CPU.
Ideally I would have liked an Arcom board because their PALs are not read-protected.
Keith
Really inelegant and I suspect it would have added unreliability even if the idea was sound.
Plasmode
Just4Fun
Trevor Johansen Aase
