I had to replace the auger again because it broke. But it's nice to be able to print spare parts whenever you need them.
09/29/2024 at 04:45 • 0 comments -
Maintenance & Cleaning
11/18/2023 at 16:12 • 0 commentsAfter several years of good use, it needs some cleaning and little repairs. And I want to test a new auger type...
I took some time to clean up the 3D model...
01/15/2023 at 18:18 • 0 commentsSince the feeder is still working fine, I took some time to clean up the 3D model. -
still works...
12/24/2021 at 21:08 • 0 comments -
After one year of use, I had to replace the auger.
09/06/2020 at 06:34 • 0 commentsAfter one year of use, I had to replace the auger.
The new auger is printed in PTEG.
I found some time to sketch up the electronic schematics:
10/19/2019 at 07:00 • 0 commentsI found some time to sketch up the electronic schematics: (please tell me if I made mistakes)
get a notification if the cat is eating
10/02/2019 at 06:01 • 0 commentsI made a flow on nodered that sends me a notification with a snapshot of an IP-cam when my cat is eating. (or when food gets refilled)
If the measured weight is in- or decreased by ≥5g a notification gets triggered...
...actual screenshot from my smartphone:
(I blurred out the image to protect my cats privacy ;) )
