Keyboard and trackpad controller
05/31/2020 at 20:22 • 0 comments5/31/20
Made some minor progress in working with an engineer on doing the keyboard and track pad circuitry. Not done yet, but still hacking away!
Trackpad woes
10/12/2019 at 03:15 • 0 commentsGot an older macbook 2008 polycarbonate top case. Wired up the keyboard to usb and was able to get the keys working but not the trackpad...
USB Headers
10/08/2019 at 08:32 • 0 commentsThis week the headers for the usb extensions arrived. I went with common 2.54mm pitch double stack header pins. I put 90 degree pins on the board and 2x 4 wire jumpers with 4 pin connectors carry the signal to the ports for the external USB. I also sourced a flexible cable for the monitor. This was a decent hurdle as the original cable was ffc which is flat, but doesn't work well for the laptop hinge. After a few wrong orders, I found the cable that worked for this project came from an inspiron 7000 series. It's an eDP 30 pin to ffc 30 pin 0.5mm pitch. I have a hunch that I can get an older macbook polycarbonate keyboard/trackpad to work so I'm ordering that. Another hackaday member, RRPrime has a good trackpad hack that might be usable for this project, and would be fun to keep as much original as possible. I understood about half of what he wrote o.O
