I've always thought the 68000 processor was a very elegant design and have had several computers in the past based on this processor. Recently, while reading through the 68000 projects here on Hackaday and throughout the Internet, I suddenly felt a slight pain in my wallet and a short time later this VME bus SBC board showed up in the mail. I have no idea how this project will go but I'm in it for the long run. My first steps are to try acquire any documentation I can on this board, put together a small VME chassis, and see if it boots.
Files
greenspring sbc1 front panel.svg
Pinouts for front panel ja and jb connectors. Shows serial port pins.
I picked up a VME backplane recently, not exactly necessary to power up the card but it will make things much easier. It will also allow me to add other cards, like a SCSI controller or VGA graphics controller. I'll likely make a cage around the backplane using 2020 extrusions and 3D print the card guides.
The one issue with this backplane is the rather non-standard power supply connection. This backplane was designed for use with a 3U Eurocard sized power supply, which would have had a mating connector and supplied power to the entire VME bus. I think I've got the pins mapped out to the proper voltages but I need to try find the pinouts of this connector before I actually power things up.
The power supply I will be using with this is a Power-One MAP80-4010. This switch mode psu outputs +5V @ 14A, -5V @ 1A, +12v @ 4A, and -12v @ 3A. Should be perfect for a small system with maybe 3 boards.
As always, if your reading this page and have information about the CPU board or this backplane, please let me know.
I have 6U Motorola 19: chassis with 12 slots, MVME162-13 board (year 1992) and run OS-9. I have also XVME-653 board (also 6U).
Now I started a new project - tester of digital circuits and decided to realize it on VME board for my chassis.
