1Video Instruction
3Step 2. Add Component
#1 Click '+' (Add Component Button) to search and select the component.
#2 ① Type 'Button' on the search bar or find the Button module on the list.
#3 ② Select Button
#4 then you can see ③ pin indication. (You can configure it.)
*This module has 3 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for Button Module] in case of Arduino UNO
Signal: 0
VCC: 5V
GND: GND
#5 After configuring pins ④ click ADD button on the right below side
#6 ⑤Added Module has appeared on the right panel
4skiiiD Code of Button Module
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
isClicked() - This code shows 1 as clicked status, and 0 as unclicked status.
