- This video shows that 36:1 Compound Planetary Gear Assemble Process.
- This video shows that 36:1 Compound Planetary Gear Test Video using MJ-VESC (https://hackaday.io/project/167706-mj-vesc-arduino-shield-type-ver-01).
Epicycle Planetary Gear (Compound Gear) + Tarot 5008 340kv motor
2019_10_07.ML5008_actuator_191019.zipThis is the inventor file. Open project file('.ipj') first and then open assembly file (Compound_planetary_ver3.iam).x-zip-compressed - 49.08 MB - 10/19/2019 at 02:07 |
When the center distance of 1st is 20mm, and the planetary gear
teeth of 2nd is 17, the Internal gear teeth should be 57
Awesome job! I have actually also designed a 3D printed gearbox that is in some regards VERY similar to this for my ebike. When I found this project I was quite surprised about how similar some of our solutions are.
Which material did you print this gearbox in? I printed mine from POM, but it is very difficult because of the insane warping.
