Hackaday.io Hackaday.io
Sign up Log in
USB to 4 RS232 Ports
A 4 port RS232 Adapter
bharbourBharbour
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
13 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
838
4
13
7
Team (1)
  • bharbourBharbour
Join this project's team
completed project
hardware
This project was created on 10/17/2019 and last updated 5 years ago.
Description
This is a simple USB to 4 port RS232 converter board. Modern PCs (cheap ones anyway) generally don't have RS232 ports anymore. I am working on a data acquisition system that will require multiple RS232 ports to talk to different instruments. One of the problems with USB is that you can't guarantee that every time the system boots, the USB components will enumerate to the same devices. It would be possible to use multiple, single port USB to RS232 adapters to connect to the instruments, except that each time the system reboots, the instruments could appear on different TTYs. Using a single USB device with 4 UARTs in it insures that ttyUSB0 connects to the same physical device every boot cycle.
Files
USB_Quad_RS232_IF_V1p2.pdf
Schematic of Board with updates added.
Adobe Portable Document Format - 503.66 kB - 11/04/2022 at 23:17
Preview
Bill of Materials-USB_Quad_RS232_IF.csv
Bill of Materials for Board
Comma-Separated Values - 2.91 kB - 10/17/2019 at 21:07
Download
Project Logs
Collapse
  • Minor change
    Bharbour • 05/18/2022 at 20:28 • 0 comments
    Pin 1 on the 4 RS232 D connectors should be left open rather than tied to ground.
View project log
Log In/Sign up to comment
Sign up with Github
OR
BrendanSmithLilydale wrote 10/13/2022 at 06:02 • point
I know its a lot to ask....PCB schematics gerbers?  KIkad or Eagle?  Many thanks
Bharbour wrote 11/04/2022 at 21:20 • point
Sorry to take a while to get back to you. This project was done in Altium Designer, so no Kicad or Eagle project. The PDF schematic and Bill of Materials are in the files section.
Bharbour wrote 10/18/2019 at 13:49 • point
Thanks, that part looks good! I have been using FTDI parts through the years and have had good luck with them, so they are my first choice for stuff like this.
Saimon wrote 10/18/2019 at 11:16 • point
There is also the CP2108 that is cheaper than the FTDI chip!
Adding a internal USB hub and SDR to uConsole
Project Owner Contributor
The uConsole Implant
luis-rodriguezLuis Rodriguez
Gotta have more USB ports
4 port USB hub in a square inch
mitchelldokkenmitchell.dokken
This step mainly verifies the two UART ports, the USB port, the screen of our development board, and whether the firmware runs correctly.
Quick Start of UWB Module——Power-On Test
ai-thinkerAi-Thinker
How to redirect USB modem to a VMware ESXi virtual machine
Redirect USB modem to a VMware ESXi
oliverOliver
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "USB to 4 RS232 Ports", please tell us the reason.
Send message
Remove Member
