USB_Quad_RS232_IF_V1p2.pdfSchematic of Board with updates added.Adobe Portable Document Format - 503.66 kB - 11/04/2022 at 23:17 |
Bill of Materials-USB_Quad_RS232_IF.csvBill of Materials for BoardComma-Separated Values - 2.91 kB - 10/17/2019 at 21:07 |
Pin 1 on the 4 RS232 D connectors should be left open rather than tied to ground.
Sorry to take a while to get back to you. This project was done in Altium Designer, so no Kicad or Eagle project. The PDF schematic and Bill of Materials are in the files section.
Thanks, that part looks good! I have been using FTDI parts through the years and have had good luck with them, so they are my first choice for stuff like this.
There is also the CP2108 that is cheaper than the FTDI chip!
I know its a lot to ask....PCB schematics gerbers? KIkad or Eagle? Many thanks
