MCH mount. Episode 2
A project log for Reflow micro table (archived)
Micro table to reflow small boards.
vitalyVitaly 11/04/2019 at 15:460 Comments
Finally, after waiting for new materials, checked some ideas and here are new details about MCH mounting.
New heroes :)
Left is with:
Right is with:
Don't pay attetntion to dirty surfaces, that's after testing coverage quality.
Heater bottom side barrier
I wished to find better replacement for high temp silver paint. Classic solution to reduce IR emission is aluminium foil. So, needed to find suitable foil thickness (convenient to work with) and suitable glue (good at 300-400C).
First, any foil is ok to reduce (or reflect) IR emission. But too thick foil may be not convenient for mount. After search, i found nice foil in disposable aluminium baking forms :). It's ~ 60um thick (kitchen foil is 10-20um), cheap and easy to buy. The only advice i can give - select form with flat bottom.
Glue is a different story. There are only 2 types of accessible glues for desired temperature range:
Problem is, we need thick layer, and this glues dry not well without air. Also, cement is not convenient for work.
Since foil on MCH bottom does not need full surface bonding, we can use gasket maker. If we put small glue points on corners and between, that will be enough to hold foil well. And glue will dry completely in 1-2 days.
I selected copper-filled gasket maker, to use it again later as thermally conductive glue for RTD sensor.
How to bond:
Heater top side cover
I had idea to use Panasonic PGS to equalize surface temperature. But, to be honest, amount of problems are not proportional to added value.
Of cause, there are 2-component epoxies and thermally-cured 1-component glues, able to work at 300+ C. But those are not cheap, and not widely available.
Here are 2 thermal images, as a result of experiments. Don't be too critical to temperature values - i used different paints and did not tuned camera.
Ordinary black top:
Top with PGS (poorly bonded with copper-filled silicone gasket maker):
So, may be, PGS can help a bit, but it's not "magical" for this appliance.
My opinion is - use any black paint, able to work at 400C and more. Usually, all such paints have good adhesion to ceramic. So, select the cheapest one. Take care to manial, usually after dry, heating at 180C (or more) required for 1-2 hours. Since we paint heater - that's not a problem at all.
Useable heater area
As you can see on thermal images, ~15-20mm from power wires are not heated well. The rest is ok, if we do some discount for hobby use:
I'd say, there will be ~30*45mm of "solderable space". Very nice.
Is it possible to do something better? Yes, of cause. But advantage of this device is to be small and easy to do, good for rare use. Such simplicity compensates it's disadvantages for many cases. If you need something better - use microwave ovens, bga reball stations and so on. Segment of bigger devices is already well-covered.
PCB reflective layer & mounting
PCB cover is not principal, because almost everything is already dimmed by heater's foil. Use any reflective adhesive tape, suitable for termal insulation - pure aluminium, or something reinforced.
As you can see on first image, left unit uses reinforced gold foil tape for auto, right unit uses ordinary aluminium tape. No principal difference.
Here is is PCB bottom view from thermal camera:
As you can see, most of heat goes via metal mounts. Most depends on contact between DIN914 screws and brass inserts. When top screw are inside inserts less than 2.0-2.5mm, result is good.
Currently, when used 10mm length inserts and 10mm screws, air gap is 17-18mm air gap. Not too bad, but i would try to reduce. Also, switch from M3 to M2 screws can improve situation a bit.
Summary, and what's next
  1. After experiments, fount optimal combination of materials - accessible, cheap and easy to work with.
  2. Ordered M2 screws and inserts of different length, to try reduced air gap.
So, i hope next iteration become be final.
