General Architecture
10/31/2019 at 16:41 • 0 commentsThe goal is to create a viable CPU with its own language able to run simple programs.
It is based on a Von Neumann architecture with the following features:
- 8 bit shared data bus
- 8 bit general purpose A register
- 8 bit general purpose B register
- 8 bit Program Counter register
- 8 bit Instruction register
- 8 bit memory address register
- 256 bytes non volatile static RAM
- Led visualisation at each level (registers, bus, status, etc)
- Dip switch manual entry (bus value, memory adrress and data programming)
- 4 digit 7 segment led display (signed / unsigned values)
- ALU with add / substract functions and the capability to evolve to more features
- Flag register with Carry Flag, Zero Flag
- EEPROM based instruction decoder with up to 24 action signals
- variable speed and step by step clock
The general architecture will evolve with updates to the project. However here are the basic elements:
The following modules will be detailed (order may vary):
- Bus module with bus value display and manual setting
- A & B registers (General purpose registers)
- Program Counter
- Memory including Memory Address register, Manual RAM loader, Ram out driver
- ALU with it's basic add/substract function, Flags register, R register (ALU result register)
- Instruction register
- Instruction decoder, stepper
- Input / Output, 7 segment display module
And of course, in order to understand the inner mechanics of the CPU:
- Micro instructions (action signals)
- Steps description
- Macro instruction
