infrasound_monitor_program_files.zip
Raspberry Pi Infrasound Monitor -- program files and installation instructions -- updated 1-June-2023
Zip Archive -
321.96 kB -
06/01/2023 at 18:21
Download
InfrasoundMonitorPresentation.pdf
An overview of the system
Adobe Portable Document Format -
6.69 MB -
05/19/2020 at 13:18
Preview
Comparing two windfilters, foam block and porous hose.
JPEG Image -
287.61 kB -
04/26/2020 at 12:45
Preview
ConstructingInfrasoundMonitor.pdf
Full construction details
6.30 MB -
04/20/2020 at 15:38
Preview
Signal from near wind turbine showing fundamental frequency (0.7Hz) and harmonics.
Portable Network Graphics (PNG) -
69.95 kB -
10/20/2019 at 10:25
Preview
4 day plot of acoustic power (0.05-2Hz). Region between red and blue vertical lines is signal due to a chemical plant 'flaring' approx 10km away.
114.97 kB -
10/20/2019 at 10:16
Preview
Continuous wavelet transform of a reading.
100.79 kB -
10/20/2019 at 10:11
Preview
Use of porous garden hose as wind filter outdoors
JPEG Image -
72.51 kB -
10/20/2019 at 10:11
Preview
Initial sensor casing - aluminium case at bottom is a pneumatic filter to eliminate pressure variation with a period above ~100s
223.83 kB -
10/20/2019 at 10:11
Preview
JPEG Image -
141.38 kB -
10/20/2019 at 10:08
Preview
