I've used one 5v relais to open and close the valve, a capacitive moisture sensor to measure the watering process in a jar, to handle everything I've used a Wemos. I had to use a 7805 voltage regulator to power everything with a 9V power supply, and I've used a heat sink with the 7805 to reduce the heat.
The code running on the Wemos was written with Arduino IDE.
The App for Android was made with Adobe phonegap, a free tool that lets you make an APK from web files like HTML/CSS/JS.
My home router was used to nat the local ip to a port of the router to call the app from Internet when my smartphone isn't connected to the home wifi.
Here is the schema:
(9V battery is a AC power supply plugged in the wall plug)
Giulio Pons
John Grant
Nuno Cruz
James Thomas
Having the right tool for the job is key when caring for your outdoor space. Hedge trimming is no different. Whether you’re a professional landscaper or a homeowner, having the best corded electric hedge trimmer is essential for tackling those difficult landscape projects. Read on to discover the top corded electric hedge trimmers tool available today.
