In the early days programs, like on other "HOME" computers were saved and loaded our programs to/from a standard cassette recorder, this seemed to work fairly well, but on some machines a program saved on a hot day, may not load on a cold day. The clock frequency (often a simple NE555 circuit ) drifted with temprature. The Interak circuit was much better then this, using an AY-3-1015 UART, dual TAPE output and relays to switch the recorder motor on and off.
It was not until we had Floopy drives 3.5" 720Kb that we had a choice of Basics and Pascal, "C" etc. This all ran under CP/M 2.2. Which we still use, even if it's now on a Compact Flash card, with 16 x 8Mb drives...
Mel
Jonathan 'theJPster' Pallant
Marek Więcek
Just finished building my interak , all up and running ! Does anyone know how to mount the cp/m bin file on windows or linux to transfer files or alternatively how to use the cp/m FT utility to copy files via serial ?
