DMON-S_original_docs.zip
Dave Parkins dug up the original DMON-S files and I have uploaded them here for your delight. Note that some characters are wrong, I think they have bit 7 set as part of a CP/M editor. These should be few, and easily correctable.
The date codes are dd/mm/yy format.
Zip Archive - 42.40 kB - 06/04/2023 at 02:21
Download
DMON.txt
Source code for DMON-M and DMON-S using conditional assembly.
Does not generate DMON-H yet. Assembles online at asm80.com
plain - 38.13 kB - 05/21/2023 at 21:42
Download
CHSSGRAF.txt
Character generator font ROM for Interak.
Contains special graphics for chess.
LABEL: CG2 V0208 870710 Size 8K in 2764.
plain - 140.33 kB - 05/21/2023 at 01:39
Download
CHSSGRAF.BIN
octet-stream - 8.00 kB - 05/15/2023 at 00:43
Download
DMON-H.BIN
Interak boot ROM V3.1.
Used with an ASCII keyboard at Port 40H and a serial VDU terminal.
No LABEL.
octet-stream - 2.00 kB - 05/15/2023 at 00:42
Download
DMON-S V3.1 1985-09-27.bin
DMON, Serial port version of DMON-M.
Removes the need for an Interak Keyboard and Video board.
octet-stream - 2.00 kB - 05/14/2023 at 01:30
Download
DMON-S V3.1 1985-09-27.hex
Hex file of DMON-S.
hex - 5.65 kB - 05/14/2023 at 01:30
Download
Interak_VDU-2K_timing_generator_2.h
VDU-K timing generator ROM, as a 4 kbyte C array of unsigned char.
x-chdr - 20.86 kB - 05/08/2023 at 15:52
Download
Interak_VDU-2K_timing_generator_2.bin
VDU-K timing generator ROM, 8k binary.
Only the first 4K is used, the last 4K is all 0xFF.
octet-stream - 8.00 kB - 05/08/2023 at 15:52
Download
Interak_VDU-K_timing_generator_1.txt
VDU-K timing generator ROM, reverse-engineered source code.
plain - 18.88 kB - 05/14/2023 at 13:00
Download
Interak_VDU-K_timing_generator_1.hex
VDU-K timing generator ROM, intel hex file.
hex - 11.28 kB - 05/07/2023 at 16:33
Download
Interak_VDU-K_timing_generator_1.bin
VDU-K timing generator ROM, 4k binary.
Only the first 2K is used, the last 2K is all 0xFF.
octet-stream - 4.00 kB - 05/07/2023 at 16:33
Download
CharGen-1.txt
Source code for the Interak character generator.
128 characters, in 8x10 character cells. 2K ROM.
plain - 51.45 kB - 05/02/2022 at 21:20
Download
VDU-L video card with V9938 chip.
Designed by Bob Eldridge but never made it to production.
Portable Network Graphics (PNG) - 696.15 kB - 03/27/2021 at 20:38
Preview
XPRN2.zip
Parallel Printer Port.
Zip Archive - 1.61 MB - 11/01/2019 at 20:37
Download
BIN.zip
De Luxe Binders.
Zip Archive - 643.75 kB - 10/29/2019 at 20:01
Download
MZC1.zip
Z380 project initial design notes.
Zip Archive - 12.98 MB - 10/28/2019 at 02:25
Download
INTK_system.zip
Interak System Notes.
Zip Archive - 7.46 MB - 10/28/2019 at 02:17
Download
INTK_description.zip
Interak System 1 Description.
Zip Archive - 6.56 MB - 10/28/2019 at 02:17
Download
XPRN3.zip
Zip Archive - 7.58 MB - 10/28/2019 at 02:10
Download
INTK_general.zip
Interak General Description.
Zip Archive - 3.85 MB - 10/28/2019 at 02:09
Download
MXD2.zip
Dynamic RAM card, 16K.
Zip Archive - 4.68 MB - 10/28/2019 at 02:09
Download
M3UDIPCX.zip
Deluxe Diplomat Metal Case Assembly.
Zip Archive - 1.12 MB - 10/28/2019 at 02:07
Download
Literature_Request.zip
Literature Request.
NB. Greenbank Electronics are not currently trading.
Zip Archive - 1.02 MB - 10/28/2019 at 02:06
Download
SBC1.zip
Z80 Single Board Computer.
Zip Archive - 15.20 MB - 10/28/2019 at 02:01
Download
AC9251.zip
Aztec CPU AC9251 Data and Mounting.
Zip Archive - 729.11 kB - 10/28/2019 at 01:59
Download
VDTI1.zip
Video Display Terminals, with Keyboards.
Zip Archive - 386.60 kB - 10/28/2019 at 01:59
Download
6402_board.zip
Serial board using the 6402. Photos only.
Zip Archive - 127.72 kB - 10/28/2019 at 01:58
Download
price_list.zip
Interak Price List
Zip Archive - 115.31 kB - 10/28/2019 at 01:57
Download
ISBUS.zip
Interak Bus
Zip Archive - 14.00 MB - 10/28/2019 at 01:45
Download
PCG.zip
Programmable Character Generator for the VDUK
Zip Archive - 6.41 MB - 10/28/2019 at 01:45
Download
PSD.zip
Power Supply Distribution.
Zip Archive - 6.73 MB - 10/28/2019 at 01:41
Download
RTC1.zip
Real Time Clock board, using MC146818 chip.
Zip Archive - 2.70 MB - 10/28/2019 at 01:39
Download
LKP1.zip
Latched Keyboard Port.
Zip Archive - 29.89 MB - 10/27/2019 at 22:54
Download
QS1.zip
Quad Serial board.
application/zip - 15.24 MB - 10/27/2019 at 22:37
Download
MPP2.zip
Memory-mapped PROM Programmer.
Zip Archive - 421.82 kB - 10/27/2019 at 22:36
Download
RI12.zip
Relay Output Board.
Zip Archive - 1.17 MB - 10/27/2019 at 22:25
Download
TCP1.zip
Tape Cassette Player.
Just brief data sheet.
Zip Archive - 270.07 kB - 10/27/2019 at 22:23
Download
2012-03-07_Interak_Port_Map.zip
Interak I/O Port map
Zip Archive - 2.01 kB - 10/27/2019 at 22:19
Download
HSDEV.zip
Hi-Soft Development package.
Zip Archive - 1.03 MB - 10/27/2019 at 22:17
Download
RRM14.zip
14K RAM/ROM board.
Zip Archive - 13.86 MB - 10/27/2019 at 22:08
Download
COMS3.zip
Serial Communications board. No manual or data sheet, just circuit sketches.
Zip Archive - 3.73 MB - 10/27/2019 at 22:01
Download
DTI.zip
Dual Tape Interface.
Just brief data sheet for now.
Zip Archive - 0 bytes - 10/27/2019 at 21:55
Download
FDD1.zip
Floppy Disk Drive.
application/zip - 1.32 MB - 10/27/2019 at 21:52
Download
DIP.zip
DIP chip prototyping board.
Zip Archive - 1.96 MB - 10/27/2019 at 21:49
Download
FDC.zip
Floppy Disk Controller.
Zip Archive - 36.30 MB - 10/27/2019 at 21:49
Download
EXTN.zip
Bus extender card.
Just scans and brief data sheet for now.
Zip Archive - 425.89 kB - 10/27/2019 at 21:37
Download
DRM64.zip
DRM64. 64K DRAM board.
Zip Archive - 4.84 MB - 10/27/2019 at 21:31
Download
DMON.zip
DMON-M Disk Monitor. Manual, source code and listing.
Zip Archive - 11.81 MB - 10/27/2019 at 21:27
Download
CPM_details.zip
CP/M details
application/zip - 7.42 MB - 10/27/2019 at 21:09
Download
CPM_Plus_user_manual.zip
CP/M+ User Manual
Zip Archive - 6.81 MB - 10/27/2019 at 20:44
Download
PSG2.zip
PSG-2 Programmable Sound Generator.
Zip Archive - 1.57 MB - 10/27/2019 at 20:39
Download
3URACK.zip
3U rack assembly instructions.
Zip Archive - 1.07 MB - 10/27/2019 at 20:31
Download
PGM-1_EPROMProgrammer.pdf
PGM-1 EPROM programmer board
Adobe Portable Document Format - 2.62 MB - 10/27/2019 at 20:12
Preview
MZB80.zip
MZB80 Z80 processor board
Zip Archive - 17.02 MB - 10/27/2019 at 20:06
Download
ZYMON64.zip
ZYMON Z80 monitor. No manual, presumably an extension of ZYMON2. No source code.
Zip Archive - 76.54 kB - 10/27/2019 at 19:46
Download
ZYMON2.zip
ZYMON Z80 monitor manual and source code.
Zip Archive - 11.41 MB - 10/27/2019 at 19:34
Download
ZYBASIC.zip
ZYBASIC Z80 BASIC and Manual.
application/zip - 1.79 MB - 10/27/2019 at 19:19
Download
VDU2K.zip
Video board based on the Z80.
Presumably an evolution of the VDUK.
Zip Archive - 7.12 MB - 10/27/2019 at 19:09
Download
VDUK.zip
Zip Archive - 8.88 MB - 10/27/2019 at 19:03
Download
MZB3.zip
MZB3 Z80 processor board.
Zip Archive - 8.36 MB - 10/27/2019 at 18:22
Download
Interak-top-level.zip
Top level files. Unzip into a directory called "Greenbank" or "Interak", and unzip other zip files into sub-directories.
Zip Archive - 4.59 kB - 10/27/2019 at 18:05
Download
