This Thermoter is based a low cost BLE solution, with which we can make the final project cost <1$. there 2 temperature sensor on the board, which i drilled holes on the case to make it out, and also 2 presice chanel for temperature compensating , to make the temperature output error <0.1 degree, in its testing arrange(Celsius 30 ~ 40 ).
The most important spec:
- Thin& small ... i intends to make it diameter less than 20mm, and thickness 1.6mm plus the components, same size as a 2016 battery .
- Low cost
- Long life, > 100 days with CR2016 battery.
- Easy& confortable.
Makerfabs
ScarsFun
Pure Engineering
@Gerben https://item.taobao.com/item.htm?spm=a1z09.2.0.0.3c402e8dRjvjXr&id=535839818548&_u=tjk0bbv251f&qq-pf-to=pcqq.c2c
