mpptproto-1_1-b20.zip
Source code: replaces low output voltage check with over-current & addition of 'sweep' P&O algorithm.
Zip Archive -
45.21 kB -
02/16/2020 at 13:13
Download
binary.h
Shared include file required to build the firmware.
x-chdr -
883.00 bytes -
11/01/2019 at 01:19
Download
mpptproto-l1-r1.pdf
Design spec sheet for buck inductor.
Adobe Portable Document Format -
67.85 kB -
10/31/2019 at 18:03
Preview
mpptproto-config-191030.pdf
PDF of PIC peripheral configuration for gate drive, control loops and synchronous low-side.
21.70 kB -
10/31/2019 at 18:02
Preview
mpptproto-config-190613.sch
Autodesk Eagle schematic as-built. Only install components from BOM that are also listed here. Additional components have part# attribute with Digikey part number.
sch -
31.93 kB -
10/31/2019 at 18:00
Download
mpptproto-190613-s2.pdf
PDF of schematic, page 2 of 2.
20.65 kB -
10/31/2019 at 18:00
Preview
mpptproto-190613-s1.pdf
PDF of schematic, page 1 of 2.
25.91 kB -
10/31/2019 at 18:00
Preview
mpptproto-190613-b.pdf
PDF of board with annotations for modifications to stock 125vbuck PCB.
82.99 kB -
10/31/2019 at 17:58
Preview
mpptproto.xlsx
Excel design workbook including BOM.
sheet -
83.87 kB -
10/31/2019 at 17:58
Download
mpptproto_1-0.X.zip
MPLAB project folder containing all firmware source. Should compile in 'free' mode.
Zip Archive -
658.88 kB -
10/31/2019 at 17:57
Download
