A logic-analysator style program, to get some insight on Raspi Gpio pins.
LogicSrc.zipProject source to compile on a Raspi. Licence: GPL includes Bcm2835 lib (c) Mike McCauleyZip Archive - 117.32 kB - 11/02/2019 at 08:36 |
extract zip:
unzip LogicSrc.zip
Dependencies libgtkmm-3.0:
sudo apt-get libgtkmm-3.0
change dir:
cd Logic
make
Setup:
add dtoverlay=gpio-no-irq to /boot/config.txt
Reboot important to keep your pi running!!!
Run:
dist/Debug/GNU-Linux/logic
For a first external signal connect a switch to Gpio 4 (Raspi 40 pin header pin 7 Gpio pinout) and Ground (pin 9).
With the program you now choose the Trigger 4 and "Single" (capture) and activate the switch.
In a moment you see that a switch is not just on or off but usually bounces back and forth some times.
