Commodore 64 PAL to RGB Adaptor
Decodes the PAL video output from a Commodore 64 for use with an RGB monitor.
I have a Commodore 64 that I acquired from a junk shop for $5. The C64 does not have any kind of RGB video output, and I don't have a suitable monitor or TV set with a composite video input. However, I had some parts salvaged from the colour circuitry of an old TV set, so I decided to try building a PAL to RGB decoder. I was mostly successful.
I have put a full schematic and a discussion of how it works and what I learned during development on my web page, see the Project Writeup link above.
Edgar Kogler wrote 11/10/2019 at 17:57 point
Hi greg, I owned a C64 in the 80ies with the original Commodore Monitor and it had the same issue as you describe with certain combinations of colors.
So, you've done a great job :-D and stand in line with the commercial producers !
Edgar
