There have been a number of digital logic projects that use relays. Most relay logic I've seen relies heavily on double-throw (form C) relays. I'm interested in circuits that use the simpler single-throw kind of relay.
SPST relays (1 form A) have a number of advantages. They're the simplest, cheapest, and generally the most reliable kind of relay. Also, most reed relays are SPST-NO relays, and reed relays also have some advantages for logic.
So, what can be built with just SPST relays?
Mechanical is fun, but transmissions gates are worth at least being aware of.
Dual SPST, 3 Ohms when closed, 4.5nS to switch, 250pS to propagate.
ti.com/lit/ds/symlink/sn74cbt3306c.pdf
Provides no easy way to fake a diode bridge XOR across the coil though.
DPQT like 74CBT3253 provide a straighforward way to fake that bridge.
More throws than you were after, but no obligation to connect all of them.
