Starting ...
A project log for Temperature control for small modeling iron
Adding a small circuit for exact temperature control to a modeling iron
edgar-koglerEdgar Kogler • 11/10/2019 at 17:41•0 Comments
5.11.2019
I disassembled the iron and started choosing the controlcircuit and a fitting thermistor.
Since thermistors ready for 300°C are rather expensive I chose one with 150°C limit.
An alternative solution seemed to use an existing thermostat from an baking oven, but they are too big for my purpose.
10.11.2019
I chose the circuit of Oliver Pering:
http://hobbyelektronik.de/praxis/projekte/temperatur-schaltstufe/
I had a nice time calculating resistor values for the voltage dividers used to switch the heating via the OpAmp (the good old workhorse, a historic LM741 ;-) )
