The PCB for the crazy tiny keyboard arrived as well, and I had a stab at soldering the buttons by hand. I got as far as the second button of the second row and decided that it's not going to work. My tiny soldering iron tip is simply too big for this.
I might give it another try with solder paste and hot air gun, but I really don't have much hope for it. It's also pretty inconvenient for typing with your thumbs, so I guess I will just call this one a failure.
have you tried the sand filled frying pan method?
https://hackaday.com/2019/06/05/solder-smds-with-a-pan-o-sand/
I'm describing everything I try in here.
i used smartphone q10 blackberry keyboard for typing for my small device. it's with backlit, cheap, easy to make and comfortable to use. almost impossible to make something similar from ordinary parts ( i tried...
Yeah, I just wanted to see how hard it would be to just use regular switches. Now I know.
