This is a GPS shield for a Feather board. It uses the SAM-M8Q GPS module from U-blox. It is designed to be place directly onto a Feather board and use the UART or I2C lines of the Feather to communicate. No external antenna is required, as there is one built into the GPS module. The GPS module is configured using the Sparkfun GPS Library. It can be used to output NMEA strings that contain positional data which can be used by the Feather. Two LED's on the board indicate the power and fix status of the GPS module. This module uses battery-backed RAM, which allows the the GPS to retain it's position data and obtain a faster fix upon reboot.
Chris Hamilton
