How can I easily and quickly describe the programming model ?
It originates from a study of microkernels but now I realise it features "Object-Oriented" traits. So it's a sort of object-oriented microkernel, or whatever...
I was really interested to learn the ideas of GNU HURD, in particular that "everything is a server" and the user/root split is replaced by credentials. Today is looks great to me as I poke holes into the POSIX paradigms, but it was not obvious back in the days, despite the claims of the benefits. It takes time to balance them with the drawbacks, the most prominent one being to re-learn to code, structure, manage this concept, which will percolate slowly, very slowly through a software collection. So slowly in fact that GNU simply provides a POSIX compatibility layer, making the whole effort moot...
OTOH, basic OO programming has some simple concepts: an object is a module that bundles data and code, of which there are private and public ones. Inheritance provides enhancements, and a few more clever concepts that I understand but find no use in my projects. I have written a Java program for a project 25 years ago and I still dislike it, though the necessary boilerplate seems to be more or less accepted, while the similar verboseness of Ada/VHDL is often criticised by newcomers. Whatever.
The convergence of OOp and capabilities-based microkernels however provides something really interesting. The overall structure of NPM can be used to implement a strict OOp system but we're not going for a iAPX432 remake, the ABI is very simple and requires little complexity on the platform side.
The similarity became apparent when I saw that the module's entry points could be seen as an object's public functions. Data are private unless shared with a specific mechanism (zero-copy becomes tricky though). The "init" entry point is close to the "new" or constructor of an object. The more I look, the more I see the parallels and it appears that object-oriented languages could be ported, with some modifications, which would lower the barrier of entry in this new world.
Does that mean I'm making a Java or C++ OS and processor ? No because it will remain language agnostic, though OO code would be quite easy to program and port there. Pure procedural code is probably easier to write but will require the understanding and knowledge of the paradigm, but if I say "it's OOp-like" then people will adopt many prerequisite coding habits. It might even justify the limitation of the size of the entry point area because people will see and understand why a program should not be overly complex. However there is no support for things like virtual tables or anything dynamic.
The BIG problem will be with the data pointers, as there is no "system-level heap". Modules/objects must communicate via private, peer-to-peer channels with some kind of address space right delegation. Most OO programs don't have to deal with different address spaces or access rights tied to an object, because classical OO programs share a single executable's virtual space and the OS does the policing.
OO programs could be made a bit more robust by adopting some of the proposed mechanisms but the classical OO structure is already stringent enough to help with adoption.
