POSEVEN
An architecture for OSes, languages and application processors, that emphasises speed, safety, security and modularity.
Public Chat
Because POSIX (at the lower levels) is totally tied to the C language which descends from 60s era DEC PDPs idiosynchrasies, it too has become unsuitable for modern computing, holding it back more than helping. It survives from its tight integration with countless other software domains and the huge installed base, but the fundamentals have never been seriously challenged.
So let us take a deep breath and make an abstract and holistic definition for a system architecture, both hardware and software, revisit old classics and recombine them in hopefully more convenient and secure ways.
POSEVEN is not an operating system.
POSEVEN proposes a clean, clear, modern architecture where CPU design, programming languages and operating systems meet. Thus it is both a programming model and the underlying structure of post-microkernel OSes, designed such that microprocessors are simple, safe and efficient. POSEVEN' threat model assumes corruption, not purity, and promotes containment at the lowest levels.
It sounds ambitious but it has become even more necessary.
This project discusses about general computer program organisation. For lower-level CPU design tricks, dos and don'ts, please check it out: #PDP - Processor Design Principles :-)
Observation : The way we are used to program computers is a long evolution, and selective pressure has favoured bad habits and false good ideas, among others.
Safety and security are not guaranteed, ASLR and NoExecute flags don't prevent the constant stream of dumb and preventable vulnerabilities (out of range access, buffer overflows, stack smashing, various leaks, Return-Oriented-Programming and so many other exploit vectors). I'm not speaking about cache and buffer coherency/timing issues here, which are detailed architectural issues.
Of course, no program is flawless and "there will always be bugs" but so many of them depend on the platform allowing them. This project will not revolutionise software engineering but tries to define techniques, structures and features that prevent many of the above-mentioned exploitable side-effects of the current generation of monolithic kernels (which are themselves architectured around existing CPU's programming models, and vice versa).
This project also tries to enable a new generation of capability-based microkernels (quite close to the "actor model"), which influence this work. I tried to generalise their structure and keep the most fundamental features for inclusion as processor features.
Logs:
1. POSIX is a curse
2. Read as Zero
3. The cellular allegory
4. Introduction to the new model
5. The watered-down OO Paradigm
6. Code space structure and management
7. Executable files' structure
8. SSS : the Single-Stack Syndrome
9. Name change
10. Basics
11. Memory model
12. The trampoline
13. Auxiliary Input and Output space
14. Interrupts
  • Interrupts
    Yann Guidon / YGDES • 09/12/2026 at 17:16 • 0 comments
    Handling interrupts is very easy : these signals are treated like a IPC instruction.
    Each class of interrupt (such as maskable, non-maskable, system, IO, SW faults...) has a dedicated register with the n° of the thread (and its thread descriptor address) that manages it (plus a "ready" flag). Vectored interrupts in the class are managed through the IPC service n°. Thus there is very little special hardware to add, and no new instruction.
    A handling thread must be spawned ("pre-fork" in other contexts) before the interrupt source can be serviced.
    There is no other requirement (yet), there may be as many classes as necessary and possible.
    The interrupt registers are not specified yet.
  • Auxiliary Input and Output space
    Yann Guidon / YGDES • 02/19/2026 at 22:03 • 0 comments
    Input and output (IO) is another critical resource but it's not the central feature of POSEVEN. It still needs to be specified !
    The Code, Data and Instruction spaces are essential but some modules may inherit access to a 4th space : IO registers.
    Access to this space is exclusive : each module (why limit to thread?) can access a range (only one range ?) of IO registers, which are rather fast, but must usually enforce access protocols.
    When a thread generates an input or output request, the IO target/peripheral compares the module ID or thread ID with a valid registered ID (configured by the core module). An ID mismatch will obviously trigger an exception.
    The single-server approach might look like it increases complexity and latency, becoming a bottleneck, but overall, it ensures a coherent multiplexing of the requests as the system scales up, preventing complex semaphores, mutual locks and race conditions.
    A particular IO module may receive simultaneous requests through IPC/IPE from several threads, but this leads to one single code, a single point of decision, simplifying arbitrage. There is no risk that one module mismanages a resource shared with another module using an outdated protocol, for example.
    Furthermore, large data blocks may be transmitted through the "shuttles" and queued during the IPC, and the main thread of the module will handle and serialise all the requests.
  • The trampoline
    Yann Guidon / YGDES • 02/08/2026 at 23:42 • 0 comments
    A major feature of the POSEVEN specification is the trampoline zone at the start of the code area.
    One of the aspects is the protocol that preserves speed and security. Hardware protection makes it impossible to access accidentally but the module itself must participate with its own filtering code.
    The trampoline spans the lowest 64Ki-instruction page of the code area. Granularity would be 4 or 8 instructions so only 8Ki to 16Ki entry points (maximum) are possible.
    The trampoline zone is accessed directly from a different module by a special JUMP instruction called IPC, which expects to point to an IPE instruction. This ensure that random jumps or even scanning (spraying) do not work.
    Returning to the calling module goes through the IPR instruction, which must re-execute the calling IPC instruction to ensure the stack's integrity (and restore some registers) (so IPC is a two-mode instruction).
    IPE must be located at the first instruction of a cache line (otherwise: trap), for safety and speed. The rest of the cache line (and the following line(s)) may filter the parameter, and trap or return immediately in case of error, otherwise the code jumps to the actual code, outside of the small (somewhat) zone.
    IPR can be executed anywhere.
    Since IPE can only exist at certain addresses, the OS loader (that configures the program) can simply scan the first 64K instructions of a program, looking for the IPE opcode, and re-create a table of valid entry points. This makes it easy to create new versions of a module that preserves the high-level entry points but implements it differently (as long as the entry points remain in the same order).
    The calling programs are distributed with binaries that IPC to an entry point number, and the loader must "relocate", translate that number to the actual address of the instruction. This lookup at load time removes expensive/slow runtime lookups.
    So this whole system ensures that a dynamic library, the kernel, an application, a device driver.... use the same and only one file format and structures, there is no special case to manage in the processor.
    The trampoline also defines the granularity of the pages for code : 64K instructions per page. This first page is always (or preferably) resident, in order to keep the system fast. And with 64Ki instructions per page, a module has a low maximum number of pages. Depending on the maximum number of bits of the Program Counter:
    • 20 bits : 16 pages
    • 22 bits : 64 pages
    • 24 bits : 256 pages
    This lets the iTLB hold more simultaneous modules in cache.
    Now what can the trampoline be compared to ?
    • for Unix, that would be _start and all the signal()s. Signals are asynchronous, so is POSEVEN, so there is an expectation of concurrency. Except that absolutely arbitrary signals can be sent to a module, any quantity at any rate with any parameter....
    • The trampoline is also inspired by the interrupt/trap structure of certain DSP/CPUs, so an IRQ can directly trigger a given codepath in a given module.
    • For an object-oriented programming language, the trampoline correspond to the declaration of all public functions.
    • For Pascal, the trampoline is more or less the declarative part of a "unit". In fact, in POSEVEN, every module is a "unit", and the init system (ID0)  calls all the other units.
    So the trampoline makes all the entry points safely accessible, allowing filtering of the requests. It makes the OOP paradigm more visible at the OS/System level. It maps directly to many common programming paradigms.
    Remember :
    By default, any module may call any other module at any entry point. Spraying is not impossible and there is always the risk that "rogue discovery" takes place.
    Each module is responsible for filtering the callee : IPE provides the caller's ID and it must be compared (as well as capabilities) with safe callers. Some HW features...
  • Memory model
    Yann Guidon / YGDES • 12/23/2024 at 02:02 • 2 comments
    A big part of the programming model is the memory model : the organisation of data in memory, their roles and restrictions...
    POSEVEN follows the CDI (Control/Data/Instructions) model and has three memory spaces (four if the IO ports are counted) that are independent from each other : a pointer for one space has no meaning in another space. All spaces can be paged out and cached, but the independence prevents one space from thrashing another's.
    1) Stack (the "Control" space)
    The first and most simple memory space is the control stack. It is not accessed directly or indirectly by the program, hardware directly manages the addressing and the pointers have tags automatically added to them to prevent any confusion. Each level of stack contains two words : a data word and a pointer+tags word. Each level counts as "one" increment of the stack pointer, there is also a couple of "limit" indices to help catch abnormal conditions. This separate and protected stack is essential for the implementation of fast and efficient calls to other modules. There is no special constraint to the size of the index or the stack area, but it is usually limited by the word size : 32 or 64 bits, though going 1 billion deep (30 bits) would be pointless (see here)
    The stack space is specific to the thread. Nothing else (except thread #0 and its surrogate) can access it, to preserve the integrity of the control flow. AFAIK, the only reasons to access it outside of the running thread is for setup/diagnosis/debugging.
    2) Program
    The second area is the "Instructions" space. All instructions are supposed to have the same size so incrementing the instruction pointer (PC) directly points to the next instruction (sorry : no gadget for your ROP). There is no data and the program can not read its own "data" from this space. This is a "black box" with no "introspection", meaning that no ROP (or other hacking) can occur. The code is immutable and only the source code can know what is where, apart from the IPE in the trampoline (see below).
    The address size for a module is limited to 24 bits, probably even 22 bits (amounting to 16MB). Or 20 maybe (TBD by the ISA). With such a small size, relative addressing is pointless and the module can address itself with direct addresses embedded in the opcodes. Indirect or computed addressing is strictly limited. If you need more, modularise your program, don't let it bloat!
    Each program space is specific to a module. An IPC instruction switches the current thread to a different module with its new program space. Pointers/instruction addresses for one module are irrelevant to a different module.
    The program space is mostly homogeneous. The exception is the first 64K instructions which, at certain aligned addresses, can contain IPE instructions to allow jumping from a different module.
    3) Data
    Data belong to their own space. It is not homogeneous in its function, but the structure is always the same: a linear space made of 8-bit bytes, with a pointer that is as wide as words (32 or 64 bits).
    The MSB of the address/pointer directs to one of four main areas: The top MSB is the private(0)/Public(1) flag. Other lower MSB divide this space even more, and the address generators can trap when a pointer calculation overflows or underflows, creating a pointer to a different sub-area.
    00 : Data Stack, where parameters and recursive short-term blocs are stored.
    01 : Local/Thread-private data (private heap, local/private data, variables)
    10 : Module shared data, constants, holding the module's state, semaphores, configuration...
    11 : Interchange area, used to allocate buffers that can be sent to other modules (message passing, "shuttles")
    A pointer or address has a different meaning and shareability depending on the area/MSB:
    - a private pointer (MSB=0) can't be shared at all and will have a totally different meaning in another thread.
    - a module-shared area pointer (10) can be shared among threads running...
  • Basics
    Yann Guidon / YGDES • 07/11/2024 at 00:41 • 1 comment
    POSEVEN is based on a platform (with a proper mix of hardware and software features) that provides/implements the following two fundamental elements :
    1. Threads
    A thread is a stream of execution : a sequence of instructions that are fetched, decoded and operated upon, one after the other, with the eventual and conditional change in the sequence that is controlled by the program and/or external data.
    Nothing new here.
    A POSEVEN system may implement an arbitrary number of threads, which may be limited by hardware constraints.
    A thread can be started, paused, resumed, interrupted, frozen, thawed, swapped in/out or terminated at any time.
    A POSEVEN thread has a "global" context that contains
    • hidden, private and public properties
    • capabilities, access rights, tokens...
    • a protected stack space
    • a private as well as a shared data address space.
    A thread executes code from one module at a time.
    2. Modules
    A POSEVEN system hosts a number of modules: they contain an area of code to execute, associated with a common data memory area.
    The code is a static collection of instructions to be executed by a thread. The thread can switch from one module to another by "calling" entry points in the desired module's trampoline area, located in the first instructions of the module.
    The common data area is accessed only by the threads that execute the code of the associated module. Since any number of threads can execute a module simultaneously, all the code must be reentrant, and the relevant variables must be protected by semaphores, spinlocks or Mutexes.
    Threat model
    POSEVEN imposes modularity to promote code reuse and contain/isolate the flaws. The POSEVEN system assumes that any thread or module could be "rogue". It is the implementer's job to ensure that the "kernel" module (#0) and the "kernel" thread (ThId#0) provide the appropriate "root of trust".
    Any module can call, or be called by, a module that is potentially altered (accidentally or intentionally) so a strict separation of the modules and threads is further required.
    Communication between modules and/or threads uses strict safe interfaces:
    • The trampoline area lets a module filter calls and decide which is legitimate. Each module enforces their own (potentially dynamic) policy, by reading the "capabilities" and other attributes of the calling modules & thread.
    • Data is shared through a common data addressing area, where pointers are valid for pairs of threads. One thread may read and the other may write (but not both).
    • Calling a module is often preceded by "shielding" the thread's data stack from reads & writes, and clearing all irrelevant registers to prevent any leaks. Extra data may be left over on top of the stack by a callee module, but it can't alter the data of the caller module.
    • Each thread has its own protected stack that can only be accessed by itself, in order, through specific instructions, to prevent leaks, alterations, ROP (Return-Oriented Programming). Only the kernel and an authorised debugger can access another thread's stack's contents.
    • Paged memory helps enforce some of the security policies and helps map, or remap, code and data areas. For example : page mapping allows a given thread to access the trampoline area of another module, which enables dynamical module substitution.
    • "Resources" (hardware-controlled) may only be accessed by the "kernel" (thread #0) or one other thread, whose number is set by the kernel. In other words : the kernel manages which thread may access a given hardware resource at each time, and only one thread may handle a peripheral at a time, preventing any contention or race condition.
    POSEVEN can not prevent hardware alteration or physical bypass of access rights/tokens. However it is designed to prevent, detect and isolate "unwanted" behaviour without getting too much in the way of an application, which is free to define its own policy. Adherence to security and safety rules is the responsibility of the system designer and implementation, but the...
  • Name change
    Yann Guidon / YGDES • 12/16/2023 at 03:06 • 1 comment
    NPM is no more, welcome the new flashy and witty name :
    POSEVEN.
    Yes it's a deliberate pun, which seems to have been overlooked for decades, and the domain names seem uncluttered (yet). So I got .com as well. You never know.
    NPM was never intended to remain a definitive name for this projects/development/specification. Due to my ADHD, the name collision was a deliberate personal incentive to find a way better one, just like all those "project code names" names either Aurora, Nebula or Eclipse you see in the industry. I wanted to start the design without being hindered by the lack of a definitive umbrella name, and the ideas matter more than the label, just a few letters, put on them. But this lack was becoming a pain recently. Inspiration never warns anyway, and when it arrives, it strikes with its obviousness.
    It's seven characters long and I'd have loved a much shorter one but they are all taken already.
    What's after POSEVEN ? POEIGHT. So a system written using these principles would naturally be a POEM. Sweet, but now it's become totally corny.
    Anyway, I'm still considering this development in the background, while I work on other things like the #YGREC8. Stay tuned.
    Update: #YGREC32 will be the first dedicated platform !
  • SSS : the Single-Stack Syndrome
    Yann Guidon / YGDES • 09/08/2023 at 17:20 • 0 comments
    I remember as a teen, knowing BASIC and PASCAL, I explored the weird world of the 8086 so I could program it efficiently. And I was, and still am, scratching my head over (among other things) the concept of the stack as it was implemented by this CPU...
    I knew about stacks already, being familiar with the 6809. Stacks are cool and great. But the 8086 implements frames and contrived, uselessly elaborated. And you know what ? Stacks are one of the main weaknesses of x86, particularly when coupled with C's unbound and unchecked array, it's a highway to bugs.
    Stacks are one of the most fundamental structures in computer science and has been studied to death. Having a curiosity of FORTH, I know that a single stack is not a fatality as there are other programming languages with more than one. Indeed FORTH was creating on a computer featuring two stacks. Some languages also implement their own split stack under the hood. And that's very fine. So what happened ?
    Well, C happened more than 50 years ago and started on a PDP-7. Belonging to a certain tradition and having to run on tightly limited resources, having only one stack was a compromise that worked well enough for the time, the constraints, so it spread wildly and even overcame PASCAL.
    The single stack has one major problem in C : you can't return composite variables on the stack so function must resort to pointers and other stupid workarounds, which makes C a development hell once you go beyond the basic examples. The standard libs are a freak show. And I won't rant again about the insanity that comes from mixing control and variables data.
    The thing is : C structures (and the SSS) crystalized in many subsequent designs. Worse : it underpins modern compilers and processor architectures ! The syndrome turns into a plague.
    So...
    The NPM defines a strict split structure that separates data from control values.
    • The Control Stack is tightly controlled and only affected by the program's instructions (CALL, RETURN, IPC/IPE/IPR, THROW/CATCH etc.). The data reside in a dedicated memory space to enforce security. Nothing bad should happen as long as the program and the hardware's integrity are ensured.
    • The data stack is user-defined in the user's data space and can be placed anywhere there, in fact there could be any number of data stacks. It's up to the programmer's tastes and needs, who could shoot himself in the foot but this will not break everything. Anyway, one main data stack seems indispensable at least to support "frames" that common languages expect.
    This is expanded in the sub-project #A stack.
    This is a way to get both safety (the control stack can't be tampered with by data injection, only by modifying the read-only program) and performance (since separate access increases the ILP and there are fewer indirections due to programming kludges). The user can optimise the data stack(s) at will and even not use one when unneeded. The user stacks can grow up or down, be allocated dynamically...
    OTOH the control stack enforces security by using tagged values that define the type of the stack's contents. This is discussed at https://hackaday.io/project/8774-f-cpu/log/222000-tagged-control-stack and will certainly expand. This tagged control stack (TCS ?) can mix critical information of the program's flow state, including error handling, inter- and intra- modules calls, or even outer loops. However registers and other states must be saved through the normal datapath : apart from the Instruction Pointer, there is no provision to save the other states on the TCS, whose name implies it's only for control.
    Saving the state of the other data can be performed explicitly by code sequences and/or specific instructions. NPM/POSEVEN does not specify context switches.
  • Executable files' structure
    Yann Guidon / YGDES • 07/17/2023 at 03:24 • 1 comment
    The same file format/structure is used for every executable module : the kernel, the libraries, the applications... It does not use ELF or other existing relocatable formats because it does not need the same features. There is no symbol relocation like with POSIX systems, for example.
    The file contains 3 main sections :
    1. The list of required modules, in full text and official form, in a precise order.
    2. The data, relocated/moved to the negative range of the private addressable data space
    3. The code itself, moved to the private instruction address space
    Loading such a new module is simple:
    1. create the list of module dependencies by scanning the textual lists, look the names up and sign the dependency (with the module ID and such) to get a 64-bit hash for each called module. See the last log Code space structure and management. This may become recursive, beware of the depth.
    2. copy the data to the appropriate location and map the data space
    3. copy the instructions to the new private instruction space
    4. scan the first 64Ki instructions to create the lookup table of the entry points.
    5. call the first entry point to run initialisation.
    The first list can be empty: for example a minimalistic kernel or a basic library. These codes can be called by any other modules and threads and it's up to each module to select which rights or capabilities are protected and how. Thus a program can be built with a group of modules that call each other, registering each other's thread or module IDs to enable richer functions without the risk of interference from other programs.
    A number of entry points are to be allocated for basic enumeration and general management.
    • Entry 0 is for start/init : it's run after all the dependencies have been loaded, it can return immediately (for a kernel or lib) or go on until ... whatever (a program, a daemon, you name it)
    • Entry 1 is for suspend
    • Entry 2 is for restore/resume
    • Entry 3 is called just before shutting down/exiting/unloading the module
    • Entry 4 for enumeration of available entry points and getting the versions, name, max. num. of entries, configuration...
    When an entry point is called, the module can choose :
    • Accept anything anyway
    • Check a semaphore to accept to go further
    • Check the thread ID (given by the IPE instruction)
    • Check the module ID (also given by the IPE instruction)
    • reject everything
    The rejection can be either a polite one (IPR) or a TRAP (to signal the kernel that something fishy is happening and the caller must be flagged as intrusive).
    If the kernel must load external libs, then the bootloader must provide the appropriate access and functions to load more than one module. Ideally, the kernel must provide its own loader though but it's not a critical consideration yet.
    The module can use 2 methods, maybe simultaneously:
    • mix the code with the entry points. Compact, fast and suitable for few entry points.
    • jump from the trampoline zone almost immediately : suitable when many entry points are provided in the 64K instruction zone
    The entry points would ideally be aligned to 8 instructions boundaries to align the jump target to the cache lines, but it's not a requirement.
    ___________________
    So let's imagine a simple library that provides a single int2str (convert integer to string) function:
    • File header (could be "PM2\n") [32 bits]
    • File checksum [32 bits]
    • Some sort of specifying the ISA/CPU/word and instruction sizes
    • Size of the dependency list [32 bits] (0 in this case because no external module is required).
      • For each module name in ASCII, a PascalZ with a 8-bit prefix and NULL terminator
    • Size of constant data section [32 bits] (if larger than 31 bits, it's clearly a problem)
    • Constant section
      • "loaded" flag (cleared)
      • some constant array such as "0123456789ABCDEF" (the lookup table for ASCII chars)
    • Size of variable data section (initialised to 0 and placed below the already negative data range of the above section)
    • Size of the code
    • Code section
    The code will look like this and will load at logical...
  • Code space structure and management
    Yann Guidon / YGDES • 07/16/2023 at 18:28 • 1 comment
    Here is a more formal definition for one aspect of POSEVEN, which was first imagined with the YASEP architecture (see logs 30. Log#30 : Fast and secure InterProcess Communications and 55. Log#55 : More about the IPC instructions)
    So here we go (again).
    In memory, the computer contains a collection of separate addressing spaces, each of their own size and corresponding to a given code module.
    These addressing spaces are instruction-grained: each address points to one individual, sequential instruction, regardless of its size. Thus every index gives a valid instruction and the program counter increments normally. Instruction size or packing is out of the equation for the program itself (fixed instructions sizes are recommended).
    Each module could also have their own dedicated shared data space (in the negative range ? for constants, semaphores, configuration, whatever, but it must be "safe") but the actual data must be held somewhere else, in the local thread's data context (that's another story for another log).
    The addressing space for the code modules can be any (positive) length, but
    • The shorter the better (to prevent feature creep and bug-prone cruft accumulation)
    • The first 64Ki is a trampoline zone that could be jumped to arbitrarily from anywhere.
    One module can CALL its own code but must go through the trampoline to call any other module, using a dedicated hardware stack and a trio of instructions, that enforce safety and access rights (through user code and strict separation) while maintaining performance (through static and dynamic  caching).
    The trampoline contains 64Ki instructions that could be addressed by a specific instruction only (called IPC for InterProcess Call), and it may only jump to another specific instruction (called IPE InterProcess Entry) that manages a dedicated, hardware-enforced stack. IPE can only exist in the first 64K of the code space (or it will trigger a fault) and any IPC to an instruction other than IPE will fault as well. The third instruction IPR (InterProcess Return) completes the collection and jumps back to the previous module (indicated by the dedicated hardware stack).
    The trampoline is meant to speed up repeated accesses to libraries (for example) so the IPC instruction contains the 16-bit constant index of the desired trampoline entry (while the module number maybe be stored in a register). However a program can not know in advance this index so it must first encode the entry point number, which is later translated by a kernel-driven lookup at module load time.
    Each module can not be stored and distributed with the IPC instruction itself, because the entry points will change with time independently from the program, so it uses the IPL (InterProcess Lookup) instruction which traps :
    1. The handler checks that the module number is valid
    2. Check that the entry point number exists (not out of range)
    3. The handler changes the opcode from IPL to IPC and stores the actual trampoline index in the 16-bit constant field of the opcode.
    4. The handler re-runs the instruction that trapped
    Thus on the second run, the cached entry point has been integrated into the running code and saves some time. The interprocess call should be almost as fast as a regular CALL instruction.
    If the called module has been taken down or updated, the calling module can simply be "reloaded" into the uncached state, to re-trigger the dynamic translation.
    The numbers of the modules called by a given module are also translated at load time. Let's say a computer can load up to 64K modules simultaneously, each module may be allocated a different random number after a system restart. OTOH a program or module encodes the number in its own way.
    In particular : each module contains a list of the "human readable names" starting at index 1 (constant index 0 is the microkernel's fundamental functions). This helps "match" the program's dependencies with the loaded modules, which are translated by the kernel...
  • The watered-down OO Paradigm
    Yann Guidon / YGDES • 06/16/2023 at 03:09 • 0 comments
    How can I easily and quickly describe the programming model ?
    It originates from a study of microkernels but now I realise it features "Object-Oriented" traits. So it's a sort of object-oriented microkernel, or whatever...
    I was really interested to learn the ideas of GNU HURD, in particular that "everything is a server" and the user/root split is replaced by credentials. Today is looks great to me as I poke holes into the POSIX paradigms, but it was not obvious back in the days, despite the claims of the benefits. It takes time to balance them with the drawbacks, the most prominent one being to re-learn to code, structure, manage this concept, which will percolate slowly, very slowly through a software collection. So slowly in fact that GNU/Hurd simply provides a POSIX compatibility layer, making the whole effort moot...
    OTOH, basic OO programming has some simple concepts: an object is a module that bundles data and code, of which there are private and public ones. Inheritance provides enhancements, and a few more clever concepts that I understand but find no use in my projects. I have written a Java program for a project 25 years ago and I still dislike it, though the necessary boilerplate seems to be more or less accepted, while the similar verboseness of Ada/VHDL is often criticised by newcomers. Whatever.
    The convergence of OOp and capabilities-based microkernels however provides something really interesting. The overall structure of POSEVEN can be used to implement a strict OOp system but we're not going for a iAPX432 remake, the ABI is very simple and requires minimal complexity on the platform side.
    The similarity became apparent when I saw that the module's entry points could be seen as an object's public functions. Data are private unless shared with a specific mechanism (zero-copy becomes tricky though). The "init" entry point is close to the "new" or constructor of an object. The more I look, the more I see the parallels and it appears that object-oriented languages could be ported, with some modifications, which would lower the barrier of entry in this new world.
    Does that mean I'm making a Java or C++ OS and processor ? No because it will remain language agnostic, though OO code would be quite easy to program and port there. Pure procedural code is probably easier to write but will require the understanding and knowledge of the paradigm, but if I say "it's OOp-like" then people will adopt many prerequisite coding habits. It might even justify the limitation of the size of the entry point area because people will see and understand why a program should not be overly complex. However there is no support for things like virtual tables or anything dynamic.
    The BIG problem will be with the data pointers, as there was no "system-level heap" (edit: addressed in 2025/2026). Modules/objects must communicate via private, peer-to-peer channels with some kind of address space right delegation. Most OO programs don't have to deal with different address spaces or access rights tied to an object, because classical OO programs share a single executable's virtual space and the OS does the policing.
    OO programs could be made a bit more robust by adopting some of the proposed mechanisms but the classical OO structure is already stringent enough to help with adoption.
View all 14 project logs
Yann Guidon / YGDES wrote 10/07/2024 at 08:12 • point
https://youtu.be/oNQLhcn5gvE?t=15728 (oh no.... it's ridiculous at this point)
Yann Guidon / YGDES wrote 03/16/2024 at 10:51 • point
So much is going on right now !!!
#A stack is progressing, I am currently writing an article on this subject.
I am also working on the addressing model, the MSB of the pointers in particular.
Yann Guidon / YGDES wrote 07/03/2023 at 13:37 • point
https://www.youtube.com/watch?v=lc5Np9OqDHU Even Douglas Crockford agrees.
Yann Guidon / YGDES wrote 06/25/2023 at 18:31 • point
https://chompie.rip/Blog+Posts/Put+an+io_uring+on+it+-+Exploiting+the+Linux+Kernel LOL.
