Help wanted: watch bands, spacers, nuts, screws
01/23/2020 at 19:04 • 4 comments@Kevin Walseth at Digi-Key has gotten us all the electronic components that we need.
But we also need:
- Watch bands (probably 22mm NATO)
- Mechanical parts to assemble the top and bottom board (a sandwich with the battery in the middle)
Watch Bands:
I ordered this from Amazon for Michael:
It is a 4 pack of 22mm NATO bands for $13.99. That is $3.50 each. This seems not be a good value. We need to source 300.
Standoffs:
@Michael Welling found these 7mm standoffs on Amazon but quite expensive
(1000 pcs) M3-0.5 X 7mm, Hex Female Standoffs, Metric, 4.5mm Across Flats, Aluminum
That is 1,000 pieces for $160. $0.16 each. We need 4x 300 so 1,200.
Also, we not certain what standoff is best. We are making a "sandwich" with top PCB, LiPo battery and bottom PCB:
Featured in Adafruit's Python in Hardware
01/23/2020 at 18:47 • 0 commentsAdafruit "Ask an Engineer" last night featured the Open Hardware Summit wrist badge which will run CircuitPython on a nRF52840:
Want one for your wrist? Buy tickets for OHS on March 13th in NYC! -
Prototype PCBs have arrived!
01/23/2020 at 18:35 • 0 comments@Michael Welling and Nate at SparkFun received the PCBs and stencils yesterday. @Alex Camilo should receive today. The parts from Kevin at DigiKey should arrive today at SparkFun, Michael and Kevin.
Here is Michael wearing the PCB with 22mm NATO wrist band from Amazon:
CircuitPython Slithers Into 100th Board — the OHS 2020 Badge
01/21/2020 at 18:40 • 0 commentsFeatured on Hackaday:
Thanks @Michael Welling for creating the pull requests.
Prototype status:
Michael, Alex and SparkFun should be receive by the end of this week:
PCBs from OSH Park, Stencils from OSH Stencils, parts from DigiKey.
CircuitPython support
01/17/2020 at 14:25 • 0 comments@Michael Welling got page added for the badge:
- Add support for OHS2020 Badge #103: https://github.com/adafruit/Adafruit_nRF52_Bootloader/pull/103
- Ohs2020 badge page #377: https://github.com/adafruit/circuitpython-org/pull/377
- Ohs2020 badge initial support #2528 https://github.com/adafruit/circuitpython/pull/2528
Now on the Circuit Python website:
Certified Open Source Hardware: US000214
01/16/2020 at 00:54 • 0 commentsThis project has been registered as certified Open Source Hardware:
Updates after design review
01/16/2020 at 00:45 • 0 comments@Michael Welling and @Alex Camilo have been updating the schematic and layout based on the design review:
https://github.com/oshwabadge2020/Badge-PCB/issues/15
Here is the current render from KiCad:
Even better 3D render
01/14/2020 at 17:02 • 0 commentsThanks to @Anool Mahidharia for adding the LCD and ribbon cable!
Help review layout before fab
01/13/2020 at 10:31 • 0 commentsThanks so much to @Michael Welling for finishing routing the badge.
Michael used 2 layers for the initial prototypes so we can fab them faster. There are only 8 weeks left until the Open Hardware Summit on March 13th.
https://github.com/oshwabadge2020/Badge-PCB/pull/14
For those without KiCad:
Gerbers:https://github.com/oshwabadge2020/Badge-PCB/tree/master/gerbers
Schematic PDF:
https://github.com/oshwabadge2020/Badge-PCB/tree/master/schematic.pdf
OSH Park renders:
Here is PDF of layer preview from OSH Park:
https://hackaday.io/project/168483-open-hardware-summit-2020-badge/files
ZIP of the layer renders:
https://cdn.hackaday.io/files/1684837208376672/OSH%20Park%20_%20Verify%20your%20design.zip
OSH Park shared project has hi res top and bottom render:
More 3-D models added
01/12/2020 at 19:22 • 0 commentsThanks to @Anool Mahidharia for getting more 3-D models into the KiCad design:
https://github.com/oshwabadge2020/Badge-PCB/pull/12
https://github.com/oshwabadge2020/Badge-PCB/pull/13
Here is the current render:
@Michael Welling is continuing to work on the layout:
https://github.com/mwelling/Badge-PCB/commit/0c97acd4cb632d7c1c18045bbfa1b6cb3fd3e37d
