Test #2
A project log for SpryDrive
An affordable quasi-direct drive (QDD) actuator with steel gears.
ben-bokserBen Bokser 11/17/2019 at 22:351 Comment
New and improved design. This iteration is 3 mm shorter than the previous.
I'm still getting some slight, unbalanced stiction when playing with the mechanism by hand, until it's connected to the motor. Once it's all fastened together the motion feels perfectly smooth, which is odd to me. My only guess is that the bearing support the motor provides to the sun gear is enough to fix whatever axial misalignment there is, so it's a non-issue...?
MasterOfNull wrote 09/23/2020 at 07:46 point
If the sun gear doesn't have a good bearing on it you're going to get weirdness and excess friction/cogging when you try to rotate it. It will still work, but being perfectly centered matters as you seem to have noticed.
