RAD2 has onboard datalogging capabilities, so it can be used as a very low power device. However, it is often convenient to access data in real-time. As RAD2 is Feather compatible, it can be used with any WIFI, BLE or other wireless Feather.
We have been using it with the MCCI 4610, a Feather compatible LoRaWan radio board.
Example interactive dashboard can be found at www.mouserat.org:
