So when I started the design I had started with a 16-bit wide memory. After looking a little more closely at the cartridge spec I realize there was not enough IO for 16-bit and barely enough for 8-bit so I changed gears and decided to target an 8-bit part instead. However, I continued to use a schematic symbol for a 16-bit part and just assumed that it would only use the lower half of the pins. My assumption was incorrect and actually between the two variants it roughly uses every other data pin. It also uses the other DQM pin.
Luckily half of the data pins only required remapping on the FPGA side and all the other incorrect pins went to NCs on the chip. All that was necessary was to add bodge wires to connect the right pins in.
When it came time to use it, it just worked. SDR RAM is pretty forgiving and I don’t think we were clocking it anywhere near it’s limit.
Um site que oferece análises e rankings dos principais sites de apostas e cassinos online para o público brasileiro. Ele apresenta bônus, promoções, métodos de pagamento como Pix, e suporte em português. Além disso, fornece dicas de apostas Bet seguras e responsáveis, ferramentas de comparação de odds e análises detalhadas de plataformas de jogos e apostas esportivas. A página também inclui seções dedicadas a jogos de cassino ao vivo, como roleta, blackjack e caça-níqueis.
Several types of failures can occur when design and construction errors are made in construction projects. According to recent studies, human errors are caused by a diverse range of causes and their effects can differ significantly. So I think to avoid errors in any type of project one needs to read this post. I also read essay writing website reviews online before getting help in my research paper whenever I intend to write on topics like this.
