JPEG Image - 203.60 kB - 10/29/2020 at 10:50
Preview
Gigatron.circ
Academic Gigatron circuit on Logisim replacing the 74 series chip with more explicit and easy logic circuits to understand Gigatron micro-architecture organization, plus some debugging facilities.
circ - 226.96 kB - 11/25/2019 at 19:11
Download
Megatron TTL.circ
Megatron circuit on Logisim
circ - 222.51 kB - 11/25/2019 at 19:11
Download
Gigatron TTL.circ
Gigatron circuit on Logisim, accurate as possible to the real hardware.
circ - 175.73 kB - 11/25/2019 at 19:10
Download
Nes controller.circ
NES controller circuit on Logisim.
circ - 31.96 kB - 11/25/2019 at 19:10
Download
fibonacci.ROM
Binary ROM of Fibonacci program.
rom - 78.00 bytes - 11/25/2019 at 19:10
Download
Instructions set.pdf
PDF containing the Instructions Set and some machine laguage informations for Gigatron and Megatron.
Adobe Portable Document Format - 76.56 kB - 11/25/2019 at 19:10
Preview
Keyboard.circ
Keyboard circuit on Logisim.
circ - 30.92 kB - 11/25/2019 at 19:10
Download
factorial.ROM
Binary ROM of the Factorial program.
rom - 128.00 bytes - 11/25/2019 at 19:10
Download
fibonacci.txt
Fibonacci program in assembler, can be executed on both Gigatron and Megatron.
plain - 2.46 kB - 11/25/2019 at 19:10
Download
factorial.txt
Factorial program in assembler, can be executed on both Gigatron and Megatron.
plain - 3.64 kB - 11/25/2019 at 19:10
Download
CU-Registers.ROM
Registers ROM used for Control Unit in Logisim
rom - 1.08 kB - 11/25/2019 at 19:07
Download
CU-ALU.ROM
ALU ROM used for Control Unit in Logisim
rom - 561.00 bytes - 11/25/2019 at 19:07
Download
CU-DataPath.ROM
DataPath ROM used for Control Unit in Logisim
rom - 3.01 kB - 11/25/2019 at 19:07
Download
74xx Libary.circ
74xx library used in Logisim, mandatory for Gigatron TTL and Megatron TTL
circ - 487.11 kB - 11/25/2019 at 19:06
Download
