An LVDT (Linear Variable Differential Transformer) sensor is a precise device used to measure linear displacement. It operates on the principle of electromagnetic induction, consisting of a primary coil and two secondary coils. When the core moves, it changes the inductance, producing a differential voltage proportional to the https://pricedrightplumbers.com/ displacement. LVDT sensors are known for their high accuracy, repeatability, and durability, making them ideal for applications in industrial automation
