Install wiringPi https://projects.drogon.net/raspberry-pi/wiringpi/download-and-install/ -> sudo apt-get update && sudo apt-get install git-core && git clone git://github.com/kennethreitz/requests.git && cd requests && sudo python setup.py install && cd ..
Get 433utils: git clone git://github.com/ninjablocks/433Utils.git && cd 433Utils/RPi_utils && rm RFSniffer.cpp && wget https://raw.githubusercontent.com/Astu04/Raspi_PIR_Push_notif/master/RFSniffer.cpp && nano RFSniffer.cpp // We now modify the value in this file: Remember that value for step 6. // sudo make && mv RFSniffer /var/www/
if (value == 12345) { // <--- The number
sudo apt-get update && sudo apt-get install urlwatch lighttpd && sudo urlwatch
Now we create a file /root/.urlwatch/urls.txt with: http://localhost/log.txt
$ echo 'http://localhost/log.txt' > /root/.urlwatch/urls.txt
View all 8 instructions
CustomElectronics
Josh Cole
tamberg
jakelauck
Yes, delete it Cancel
You are about to report the project "PIR Sensor with Push Notifications to Smartphone", please tell us the reason.
