Hackaday.io Hackaday.io
Sign up Log in
Feather Solar Wing
With a DC barrel connector, you can use this wing to power your feathers, measure current and keep track of charge with a fuel gauge.
axel-manssonaxel mansson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
125 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
267
0
125
0
Team (1)
  • axel-manssonaxel mansson
Join this project's team
  • ina219
ongoing project
solar Feather Feather wing MCP73871 INA219 fuel gauge max17043
This project was created on 12/01/2019 and last updated 7 years ago.
Description
This project first version uses a MCP73871 as Adafruits original solar design, and incorporates a INA219 to measure the current and power from the sun. Also, a fuel gauge is measuring the battery voltage and you can estimate how much time there is left for normal operation. In this way, you can better control sleep time for all of y'alls project. All data sent on I2C.
My high school students are going to use these in several solar science projects.
Project Logs
Collapse
  • Moved project to EDIT: this project has moved to:https://hackaday.io/project/168721-feather-solar-wing
    axel mansson • 01/15/2020 at 09:43 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
I created a proof of concept for a VAWT
Project Owner Contributor
Creating a wind turbine
bigbatbigbat
This isn't just your everyday plant system. This project will automated everything and provide API's for integration into all systems.
Fully Automated Agriculture System
joey-pongalloJoey Pongallo
An IOT Wavebouy
WaveBee
frippe75frippe75
My ongoing maximum power point tracker project for solarboat racing applications.
DieBieMPPT - PV Maximum power point tracker
danny-bokmaDanny Bokma
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Feather Solar Wing", please tell us the reason.
Send message
Remove Member
