For the "Take Flight with Feather" contest I am submitting my idea for this featherwing. It is a feather add-on board that has an AM2320 sensor for monitoring temperature and humidity. Also there is a photo/light senser to monitor light level. Additionally I would like to also add a STEMMA connector for additional external sensor to connect to it such as a moisture sensor. It is a work in progress so I hope you like it! :)
I have been wanting such a featherwing board with the feather format to easily plug onto a feather board that could connect to the internet to make a simple IoT weather machine. Also with ability to add an external sensor for water/rain or soil moisture. I think an addition of a STEMMA connector would do the trick.
B K
Leslie
