Final log for this one, it is done. The charger section is pretty successful and will likely find its way into other work.
All as-built design work is posted in the files section: look for anything dated May 2022 or later, and be sure to read thru the logs for any hacks made. The design workbook contains all the calculations for important aspects of the design.
Enjoy.
