Frame in black acrylic panel mounting.
Front USB socket for reading writing USB Memory Stick
Removable Terminal pitch 3.5mm
Power 12V / 24V
4 analogue inputs 0 = 10V or 4-20mA
1 Analog output 0-10V or 4-20mA (Loses an analog input)
8 optocoupled outputs, PNP and NPN and AC 30V 1A
12 inputs, optically isolated, 4 of which are fast with Interrupts
RS485 half duplex
SD card back, firmware upgrading, logs, config, picture, voice
Rear USB-C, programming, debug
Optional:
- Isolator DC-DC 12V/24V to 12V
- Power supply 220V to 12V
- RTC
- RS232
- Modem GSM SIM800L with voice audio
- WiFi with integrated antenna.
- WiFi with external antenna
- Bluetooth
- Ethernet
- Frame in black acrylic. for panel mounting
- Chassis metallic rear card cover.
Michele Perla
