GCode has a delay function. So you can turn your GCode file into a clock!
simplify3d_gcode - 223.51 kB - 12/16/2019 at 17:40
C Source File - 2.07 kB - 12/16/2019 at 17:40
The G4 Sxxx command allows you to pause a print for a number of seconds.
This means you can MAKE A CLOCK!
I wrote a C program to print tick marks every minute and used the G4 S60 command to delay between tick marks.
Count the layers to see what the hour is!
View project log
HA! I like it! Kind of like a "Hello, world!" program for 3D-printers.
Speaking of which, has anyone done a legit "Hello, world!" for G code? Like writing out the text on the build plate?
Ted
Dario
Darío
Thomas Heiser
Yes, delete it Cancel
You are about to report the project "3D printer clock", please tell us the reason.
