Retrex Audio
Experimentation in AY-3-8910 / AY-3-8912 sound synthesis
In which we document things that we have learned about this audio chip.
This project was started based on interest in the Vectrex gaming system, which utilized a AY-3-8912 Programmable Sound Generator.
A sampling of sounds from this era of hardware can be found in this playlist https://www.youtube.com/playlist?list=PLvJzDR3l8jZMt1rDkUpv-mvl3vuFxXKxe
A history of the chip Video Game Music Preservation Foundation Wiki
555 180Khz Clock Fuzzing
555 180khz clock fuzzing - 145.30 kB - 01/25/2020 at 00:43
Download
20200123_194546.mp4
MPEG-4 Video - 18.93 MB - 01/24/2020 at 03:48
Download
0010_0001_0100_0110
First test composition, 4 frequencies on Channel A
0010_0001_0100_0110 - 26.12 kB - 01/23/2020 at 09:09
Download
Cigarbox dev enclosure
JPEG Image - 2.26 MB - 01/23/2020 at 09:09
Preview
Breadboard wire-up dinner hack
JPEG Image - 2.13 MB - 01/23/2020 at 09:09
Preview
View all 10 files
  • ESP32 & MicroPython 4-bit chopper
    xBeau01/25/2020 at 08:24 0 comments
    Converting setup to run on ESP32 rather than off of Arduino. Did some bit bang poking with an external clock and got it to make a sound. Hacked up some code to initialize and use ESP32 GPIO 22 for clock (Also tried 18 with hardware SPI, different challenges).
    There's a issue with PWM using 10-bit duty resolution and limiting the frequency to just of 78Khz. This should be able to go up to 40Mhz with 1-bit resolution duty, but gonna track that down later.
    Here's what generators a "chopper" noise.
    Utilizing the WiFi is totally optional, configured so that I can update main.py using WebREPL.
    from time import sleep, sleep_ms, sleep_us
    from machine import Pin, PWM
    import network
    print("AY-3-8910 teal 00:10")
    #bork break
    sleep(1)
    sta = network.WLAN(network.STA_IF)
    sta.active(True)
    sta.connect('SSID', 'PASSWORD')
    print("WiFi Started")
    #      dir 1
    #INACT  0  0
    #LATCH  1  1
    #WRITE  1  0
    #READ   0  1
    bdir = Pin(17, Pin.OUT, value=0)
    bc1 = Pin(16, Pin.OUT, value=0)
    da0 = Pin(32, Pin.OUT, value=0)
    da1 = Pin(33, Pin.OUT, value=0)
    da2 = Pin(25, Pin.OUT, value=0)
    da3 = Pin(26, Pin.OUT, value=0)
    clock = PWM(Pin(22), 78000)
    def inact():
      bdir.off()
      bc1.off()
      sleep_ms(1)
    def latch():
      bdir.on()
      bc1.on()
      sleep_ms(1)
    def write():
      bdir.on()
      bc1.off()
      sleep_ms(1)
    def read():
      bdir.off()
      bc.on()
      sleep_ms(1)
    print("Initializing 'A'")
    #Enable Register 8 (A Level)
    latch()
    da0.off()
    da1.off()
    da2.off()
    da3.on()
    inact()
    #Write A Level
    write()
    da0.on()
    da1.on()
    da2.on()
    da3.on()
    inact()
    #Enable Register 1 (A Frequency)
    latch()
    da0.on()
    da1.off()
    da2.off()
    da3.off()
    inact()
    #Write A Frequency
    write()
    da0.off()
    da1.off()
    da2.off()
    da3.on()
    inact()
    print("b0001")
  • 555 Fuzzing into the Khz
    xBeau01/25/2020 at 00:45 0 comments
    I started building a second dev breadboard, and have been thinking thru a minimalist pin connection. The core functionality for instance of controlling some tones can be done with 4 instead of 8 data bits, and one of the bus control lines can just be pulled high instead of switched.
    I rigged a 555 to experiment with independently generating the clock signal, rather than utilizing a high speed output like most SPI interfaces in a micro controller can do. I also already have this perfectly functional AY-3 chip wired up and blooping a test sequence from an arduino.
    What do you suppose happens if I just pull the clock pin out and use the 555 running at a much lower speed instead!? Yup, you get any even bittier grittier jam.
    But wait there's more, can you imagine, what if you hook up both the 2Mhz clock and the ~180Khz 555 clock? Yup you get even awesomer FUZZ!
    Hot Fuzzy Audio Sample here!
  • It's alive!
    xBeau01/23/2020 at 09:18 0 comments
    Wired up first test chip and got it making noises and sounds!
View all 3 project logs
  • 1
    Sound Check
    This is the quick hack of another code sample "Register writer" to play a warm up sound. The hardware is based on the schematic linked in the code. Works with Arduino Uno R3 aka: 328 compatible boards.
    https://pastebin.com/raw/FehmVLQS
     *               AY-3-3910 Register writer for Arduino
     *                 (c) 2014 Manoel "Godzil" Trapier
     * All the code is made by me apart from the the timer code that
     * was inspired from code found on the internet. I'm sorry, I can't
     * remmember where.
     **************************** Licence ******************************
     * This file is licenced under the licence:
     *                    WTFPL v2 Postal Card Edition:
     *             DO WHAT THE FUCK YOU WANT TO PUBLIC LICENSE
     *                    Version 2, December 2004
     * Copyright (C) 2004 Sam Hocevar
     * Everyone is permitted to copy and distribute verbatim or modified
     * copies of this license document, and changing it is allowed as long
     * as the name is changed.
     *   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
     *  0. You just DO WHAT THE FUCK YOU WANT TO.
     *  1. If you like this software you can send me a (virtual) postals
     *     card. Details bellow:
     *             < godzil-nospambot at godzil dot net >
     * If you want to send a real postal card, send me an email, I'll
     * give you my address. Of course remove the -nospambot from my
     * e-mail address.
    *   mod xBeau 1/22/2020
    *    Wiring:
    *    https://www.986-studio.com/wp-content/uploads/2015/05/AY-3-8910_Arduino_bb-1024x716.png
    const int freqOutputPin = 11;   // OC2A output pin for ATmega328 boards
    // Constants are computed at compile time
    // If you change the prescale value, it affects CS22, CS21, and CS20
    // For a given prescale value, the eight-bit number that you
    // load into OCR2A determines the frequency according to the
    // following formulas:
    // With no prescaling, an ocr2val of 3 causes the output pin to
    // toggle the value every four CPU clock cycles. That is, the
    // period is equal to eight slock cycles.
    // With F_CPU = 16 MHz, the result is 2 MHz.
    // Note that the prescale value is just for printing; changing it here
    // does not change the clock division ratio for the timer!  To change
    // the timer prescale division, use different bits for CS22:0 below
    const int ocr2aval  = 3;
    // The following are scaled for convenient printing
    void setup_clock()
        pinMode(freqOutputPin, OUTPUT);
        // Set Timer 2 CTC mode with no prescaling.  OC2A toggles on compare match
        // WGM22:0 = 010: CTC Mode, toggle OC
        // WGM2 bits 1 and 0 are in TCCR2A,
        // WGM2 bit 2 is in TCCR2B
        // COM2A0 sets OC2A (arduino pin 11 on Uno or Duemilanove) to toggle on compare match
        TCCR2A = ((1 << WGM21) | (1 << COM2A0));
        // Set Timer 2  No prescaling  (i.e. prescale division = 1)
        // CS22:0 = 001: Use CPU clock with no prescaling
        // CS2 bits 2:0 are all in TCCR2B
        TCCR2B = (1 << CS20);
        // Make sure Compare-match register A interrupt for timer2 is disabled
        TIMSK2 = 0;
        // This value determines the output frequency
        OCR2A = ocr2aval;
    enum { INACTIVE = B00, READ = B01, WRITE = B10, ADDRESS = B11};
    void setup_data(int mode)
      switch(mode)
        default:
        case READ:
        case INACTIVE:
          DDRD = B00000000; // Set all D port as input
          DDRB &= ~0x03;
          break;
        case ADDRESS:
        case WRITE:
          DDRD = B11111111; // Set all D port as output
          DDRB |= 0x03;
          break;
    void setup_control()
      DDRC = DDRC | B00000011;
      PORTC &= ~B00000011;
    void set_control(int mode)
      PORTC = (PORTC & 111111100) | (mode);
    void SetData(unsigned char data)
      PORTD = data & 0xFC;
      PORTB = data & 0x03;
    unsigned char GetData(void)
      return (PORTD & 0xFC) | (PORTB & 0x03);
    /* Registers */
    enum
      REG_FREQ_A_LO = 0,
      REG_FREQ_A_HI,
      REG_FREQ_B_LO,
      REG_FREQ_B_HI,
      REG_FREQ_C_LO,
      REG_FREQ_C_HI,
      REG_FREQ_NOISE,
      REG_IO_MIXER,
      REG_LVL_A,
      REG_LVL_B,
      REG_LVL_C,
      REG_FREQ_ENV_LO,
      REG_FREQ_ENV_HI,
      REG_ENV_SHAPE,
      REG_IOA,
      REG_IOB
    void write_2149_reg(uint8_t reg, uint8_t value)
      setup_data(ADDRESS);
      SetData(reg & 0x0F);
      set_control(ADDRESS);
      delayMicroseconds(3);
      set_control(INACTIVE);
      delayMicroseconds(1);
      setup_data(WRITE);
      SetData(value);
      set_control(WRITE);
      delayMicroseconds(5);
      PORTD = 0;
      //setup_data(INACTIVE);
    uint8_t read_2149_reg(uint8_t reg)
      uint8_t ret = 0;
      return ret;
    char regs[14];
    int j;
    void setup()
      setup_clock();
      setup_control();
      Serial.begin(115200);
      // Be sure to kill all possible sound by setting volume to zero
      write_2149_reg(REG_LVL_A, B00000000);
      write_2149_reg(REG_LVL_B, B00000000);
      write_2149_reg(REG_LVL_C, B00000000);
      j = 0;
      Serial.println("init");
      delay(500);
      Serial.println("test");
      write_2149_reg(REG_LVL_A, B00001111);
      write_2149_reg(REG_FREQ_A_HI, B00000010);
      delay(250);
      write_2149_reg(REG_FREQ_A_HI, B00000001);
      delay(250);
      write_2149_reg(REG_FREQ_A_HI, B00000100);
      delay(250);
      write_2149_reg(REG_FREQ_A_HI, B00000110);
      delay(500);
      Serial.println("ALL OFF");
    void loop()
      int i;
      while (Serial.readBytes(regs, 14) != 14);
      for(i = 0; i < 14; i++)
        write_2149_reg(i, regs[i]);
  • 2
    Breadboard Arduino Test
    Wire hardware as follows, note that C5 was omitted and bypassed in testing and sample recordings.
    Image Source (986-studio.com)
View all instructions
