Hackaday.io Hackaday.io
Sign up Log in
nRF24L01+ Feather Wing Shield
This Feather Wing board integrates the nRF24L01+ module & allows it to communicate with other nRF24L01+ modules for low power data exchange.
mitchMitch
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
Public Chat
762
1
2
3
Team (1)
  • mitchMitch
Join this project's team
  • My Twitter
completed project
hardware
nrf24l01 Battery 2.4GHz low power Feather wing RF24
This project is submitted for
  • Take Flight with Feather
This project was created on 12/19/2019 and last updated 5 years ago.
Description
Now you can use your Feather board to make use of the nRF24L01+ 2.4ghz wireless module. It works great to create a wireless network for module-to-module data exchange. The nRF24L01+ is great at low power applications and running off a battery. The wing also features a switch to tie the nRF24L01+ IRQ pin to a input for interrupt use. It can be switched off to free up a GPIO if needed. Battery monitoring is essential in low power and remote communications so the wing incorporates a voltage divider for monitoring battery voltage to the Feather.
Components
  • 1 × nRF24L01+ 2.4ghz module
  • 2 × Resistor
  • 1 × Capacitor
  • 1 × Small Switch
Project Logs
Collapse
  • More info coming...
    Mitch • 07/19/2020 at 23:50 • 0 comments
    Schematics and files to be published this week.  Stay tuned!
  • soon...
    Mitch • 12/19/2019 at 02:18 • 0 comments
    12/18/2019
    Sent board to fabrication...  patiently awaiting...
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
LongPause wrote 11/13/2020 at 20:21 • point
Are you going to publish ?
Microcontroller platform with BLE connectivity and accelerometer
Project Owner Contributor
BLEthingy
marcelMarcel
The uninterruptible power supply module with battery charging and protection, for building smart devices with power paths' redundancy
PS4IoT_V1 Smart Power Supply Unit Module
iot-devices-llcIoT-devices, LLC
DIY modular T&M chassis for programmable power DC sources and more
EEZ Bench Box 3
denisDenis
Compact, low-power, solar + battery powered, LoRa + GPS node based on ESP32-S3 PowerFeather
DIY ESP32 solar LoRa + GPS node
powerfeatherdevpowerfeatherdev
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "nRF24L01+ Feather Wing Shield", please tell us the reason.
Send message
Remove Member
