Open Source Analog Acoustic Levitation PCB
so is it with the same principle with the Acoustic Levitator? https://www.makerfabs.com/acoustic-levitator.html
Nice project, but the diagram is a bit unclear, is there a clearer version?
What a fantastic project. I’m curious about using a levitating drop in a laser microscope. [[https://adammunich.com/laser-microscope/]] A laser microscope shines a laser through a drop of water and the shape of the drop acts as the lens to project and magnify the contents of the drop. I wonder if the drop is smooth or is agitated by the sound waves. If this works, it wouldn't be too much work to add a laser diode to the PCB.
That is actually an intriguing concept. I think I will need either higher power or more speakers to achieve that.
why would you need more speakers or higher power?
Hi amazing work, is this powerful enough to assemble images with the liquid? Much like the acoustic tweezers in this video? https://www.youtube.com/watch?v=0Up5kr5Xgcg&t=7s
unfortunately not at the moment. That will require a larger array (maybe 10 speakers).
I anticipate once I build a schlieren imaging apparatus I can fine tune the speakers and create an array that creates more powerful nodes to trap water.
I think you should write more about the operation of the device
Purpose of attiny85? you write "requires no programing" If I use 12V power supply can I remove half of schematic nad use only Ultrasonic driver?
It was a backup just in case the 4047 didn't work. It works but I kept breaking it it turns out the DRV8833 has a voltage limit of 10.8V.
I was using it to 12V, opps.
You could add a slot & tab to make the board to board mounting more solid. Also adding vias will prevent the solder pads from pulling up too easily.
There is a slot. Good idea on the vias. That was a problem on one of the boards.
I have never seen a more beautiful PCB in my life and so effectively designed !!! Great job!
Nice project! Would you be able to upload a higher resolution schematic?
