I added a very simple back-case replacement for the original Waveshare 7.5" white case with magnets. Designed also a small cover for the Eink HAT so it can be easily glued to the back of the Eink, making Epaper and HAT adaptor a single piece for easy mounting.
Please check the CALE 3D Model on Thingiverse.
CALE project has been sponsored by makers store digitspace.com
Martin Fasani
