Note: The diameter sizing for each mount was based off my pair of Leki hiking poles.
For reference:
Top Mount measured = 16mm
Middle Mount measured= 14mm measured
Bottom Mount measured= 12mm
Reduce weight and build a Yagi antenna using your hiking pole and Arrow Antenna elements
For reference:
Top Mount.stlTop Mount STL file for 3D printingStandard Tesselated Geometry - 221.08 kB - 12/27/2019 at 20:57 |
Top Mount.f3dTop Mount file for Fusion 360f3d - 147.57 kB - 12/27/2019 at 20:57 |
Middle Mount.stlMiddle Mount STL file for 3D printingStandard Tesselated Geometry - 240.61 kB - 12/27/2019 at 20:57 |
Middle Mount.f3dMiddle Mount file for Fusion 360f3d - 146.47 kB - 12/27/2019 at 20:57 |
Bottom Mount.stlBottom Mount STL file for 3D printingStandard Tesselated Geometry - 249.59 kB - 12/27/2019 at 20:57 |
Download the 3D Mount Files and print out the mounts on a 3D printer.
Take your hiking pole and extend each section till it is fully extended. Mark each top section.
Using the arrow antenna boom as a template, mark three spots for the top, middle and bottom mount locations on your hiking pole with a Sharpie marker.
