1Step 1
Download the 3D Mount Files and print out the mounts on a 3D printer.
2Step 2
Take your hiking pole and extend each section till it is fully extended. Mark each top section.
3Step 3
Using the arrow antenna boom as a template, mark three spots for the top, middle and bottom mount locations on your hiking pole with a Sharpie marker.
4Step 4
Attach your mounts, insert the 3mm bolts and carefully tighten till the mounts are snug.
5Step 5
Mark and cut each antenna element with the pipe cutter. Ream out the cut section with a step bit. Insert the arrow shaft inserts and add heat shrink bands to each side.
6Step 6
Cut 0.75″ off each threaded 8/32″ bolt so the elements will be flush when screwed together.
7Step 7
Assemble the antenna and test out with your radio.
Stuart, KB1HQS
