Features
- Processing: ARM® Cortex M33 with 1 MB Flash and 256 kB RAM
- LTE Cat-M1, LTE CAT-NB1 (NB-IoT) with Global Coverage
- GPS
- Low Power 3-axis Accelerometer
- General Purpose button
- RGB LED
- Reset button
- Battery Voltage measurement circuit
- PSM and eDRX support
- On-board eSIM & nano SIM
- ARM® Trustzone®, ARM® Cryptocell 310
- SSL / TLS & Secure FOTA support
- USB / I2C / UART / SPI / I2S with EasyDMA
- up to 18 GPIO
- up to 6 12-bit, 200ksps ADC with EasyDMA
- up to 4 PWM Units
- SWD on 6-pin TagConnect
- Preprogrammed with MCUboot bootloader for firmware upload over USB
- LiPo Charger with MPPT
- Under-voltage and Over-voltage protection
- Can be powered from multiple power sources
- Fully compatible with the Adafruit Feather / FeatherWing standard specs
Block Diagram
Pinouts
Saimon
Daniel Garcia
antiElectron
