Chiming Clock
Clock that chimes on the hours, halves, quarters
Public Chat
This clock has no display; it only chimes. It will chime on the hour and the count of the hour, or optionally the halves and quarters.
The clock runs on an ESP8266 NodeMCU to drive solenoids (or voice coils) to strike chimes. The ESP8266 keeps time and synchronizes via NTP servers.
The module has just one button to mute the clock, if desired.
The module hosts a web page for configuration and testing of the clock.
Configuration includes:
- Clock Mode - How many chimes, chime on halves, qtrs. etc.
- Mute Time - optionally can mute overnight
- NTP Server - server to get time
- Timezone
Actions include:
Test chime
Mute for next hour
This version of the clock is set to play Westminster chimes using Al tubes and Harddrive voice coils. It is installed in an old house in Tainan, Taiwan, in a semi-public place that holds events and exhibitions. Also for now the building has no glass in the windows so the chiming sound is heard out in the (albeit tiny) street!
Chiming
Here are some videos of the sound after mounting the tubes better.
Here is a version using 3 gongs (steel bowls from a thrift store) ringing 6 o'clock. This is using the "All Quarters - 3" mode (see below).
Here is my test setup, with 2 bells set as "All Quarters - 2" (see below).
Web Interface
The page shows (from top to bottom):
  • Current time
  • Clock ID (also its multicast address)
  • Clock's IP address
  • Mute status (for over-night muting)
    • Enabled
    • Start Mute time
    • End Mute time
    • Buttons to mute now for 1 or more hours, or to reset to zero hours
    • Current mute status
  • Save all settings
  • Mode drop-down
  • Time zone drop-down
  • NTP server address
  • Parameter for how long to actuate the chimes
  • 4 test buttons to test the current chime mode
  • Software version info
  • Chiming Modes
The clock can chime with different modes depending on how many chimes you have connected.
The actuators used and the patterns played are defined in Chime.h
For instance if you have (at least) 2 bells attached, you could choose "Hour + Half 1-2" which will chime the hour (4 rings for 4 o'clock) and the half (one ring).
Westminster needs 4 bells (as in the project photos) and rings all quarters.
Ship's clock needs only one bell and rings hours and halves, as seen here:
Ship's bell
Schematic
The ULN2003 is a set of transistors and fly-back diodes to power the inductive loads of the actuator coils.
Here are photos of the board.
I have connected all 7 ULN2003 inputs, but am not using them at this time.
The Button
The single button has 3 modes:
If you hold it down within 4 seconds of powering the clock up, it will reset the WifiManager so you can connect to the clock as an Access Point. This lets you setup the local Wifi configuration.
After the clock is running, the button works as a mute button, just like the one in the web interface. If you press it, it mute the clock for the next hour. If you press it a second time it will add an hour of muting, etc. The NodeMCU LED will blink the number of hours it will be muted.
If you hold the button (for more than 1/2 sec) it will cancel the current muting.
This temporary mute does not interfere with the over-night mute, if enabled.
Clock Address Detection
I used WifiManager to setup the network:
https://github.com/tzapu/WiFiManager
This work very well, but after you connect to the local Wifi, there is no way to find the IP since the clock has no display.
So I made a page with some simple JavaScript to test each of the 256 IPs in the local subnet for a particular URL "DETECT". If fount the web page will give you a link to connect to the clock.
The clock detection page is findClock.html
The Venue
This clock is located in an old house that is being renovated.
https://www.google.com/maps/place/No.+9,+Xinyi+Street,+West+Central+District,+Tainan+City,+700/@22.9994607,120.1943233,17z/data=!3m1!4b1!4m5!3m4!1s0x346e766658086991:0x5c1405a2e2df6a87!8m2!3d22.9994607!4d120.196512
Here are some photos of the house during an event:
MVI_7133.MOV
Striking Quarter Hour
quicktime - 43.55 MB - 01/03/2020 at 05:00
Download
  • 1 × ESP8266 NodeMCU
  • 1 × ULN2003 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 4 × Actuators Harddrive voice coils or solenoids
  • 4 × Connectors
  • Enclosure and Button Extension
    Scoops • 02/13/2020 at 06:45 • 0 comments
    Here is a video showing the button actions, and since I was up on a scaffold I recorded the chiming from above.
    I printed a box for the NodeMCU and for a button. (My first ever 3D print!)
    The button has an LED to give some feedback about the mute state: one flash - muted for 1 hour, two flashes - two hours, etc.
    The button box has a magnet to stick on the steel frame of the old house. The button will be put on the column near the clock.
  • New Tube Hanging
    Scoops • 01/26/2020 at 14:15 • 0 comments
    One problem I had was with a single support point, the tubes would swing a bit after the striker hits it. This could cause a double hit or missed hit depending on the swinging and time of next strike.
    I decided to drill a 2nd pair of holes and run 2 wires to support the tube. The sound is still as good as before! And now the tubes are much more stable.
View all 2 project logs
vand41k wrote 04/10/2024 at 16:47 • point
I’m
Scoops wrote 04/01/2024 at 04:33 • point
I have updated my code to fix the compilation.
Rick1972 wrote 02/22/2024 at 19:17 • point
As previous comment below, this is exactly what i am looking for to restore the chimes to an old clock however trying to compile it now results in a load of errors, is there any chance of an updated version? Thanks
natalimarcelo wrote 07/25/2023 at 19:45 • point
I really liked your chime project and wanted to replicate it, however I tried to compile it for the Node MCU, but several libraries are out of date and some variables are conflicting within the code. I'm not a skilled programmer and I was wondering if you could make the necessary updates for me to be able to compile in the Arduino IDE. Thanks for the help!
Evo Mayne wrote 07/19/2021 at 07:40 • point
Awesome one!
18923 wrote 11/08/2020 at 15:38 • point
I am trying to add a function to the clock but not having any luck.
I have the clock running perfectly with one large bell in the barn. I would like to use the same bell via the Chiming clock code to "ring it on command" so my wife can call me by ringing the bell (2X3 short rings) via a URL from her phone on the local network.
Additionally the same URL could be called by another  ESP8266 with a PIR motion detector.
Any suggestions?
Liam
Jon wrote 09/04/2020 at 21:56 • point
So are the tubes from a reclaimed chime set or did you construct them with some understanding of their tone?
Scoops wrote 09/04/2020 at 22:01 • point
I bought the tubing from a shop that sold aluminum handrails and other trim/molding. (The guy in the shop said it would never work!) Then I cut them wit the help of Lee Hite's amazing website: http://leehite.org/Chimes.htm
Jon wrote 09/04/2020 at 22:49 • point
What an amazing resource site; thanks for sharing!
Xasin wrote 09/02/2020 at 20:13 • point
I am sooo definitely going to have to make time to build these.
I want to rework my Smart Home, and a cute chime like this, linked into the clock, maybe doorbell or other notifications, would be really nice.
Thanks a lot for the inspiration - and I really like the different variations of chime you have here!
richard.wenner wrote 08/05/2020 at 21:04 • point
Have I missed something here?  How are the hard drives connected to actuate the head arm please?
Scoops wrote 08/05/2020 at 22:13 • point
I guess it was not too clear. In the photo in the posting:
you can see sort of see where I cut the traces on the hard drive circuit board and soldered the red and black wires. You could also just remove the board and solder directly to the correct pins on the connector that comes out of the bottom of the drive.
The pair of wires are then connected to the ULN2003. That is the green section in the circuit diagram.
18923 wrote 07/24/2020 at 12:46 • point
Hi, I have two problems I need help with:
1) Where/how do I run "findClock.html" from?
Running locally directly from the downloaded file location does not display any subnets, same if I copy the files to my Windows IIS and run remotely from there.
2) After configuring "wifiManager"
When I access the clock via my local network no web page is displayed, all I get is :
ON-- http://192.168.0.192:80  (404: Not Found)
ON-- http://192.168.0.192:8232  (This is a Websocket server only!)
ON-- http://192.168.0.192/DETECT  (clock-85a02e.local 192.168.0.192)
PS: I have tried Chrome, Safari, IE and Edge browsers.
Thanks,
Liam
18923 wrote 07/25/2020 at 00:36 • point
For problem 2 I was missing the Filesystem Uploader Plugin to upload files in the DATA subdirectory within the Sketch
https://randomnerdtutorials.com/install-esp8266-filesystem-uploader-arduino-ide/
All OK now
Great project, I live on a farm and this will "ding" a loud single bell in the barn.
Thank you
Liam
Scoops wrote 08/05/2020 at 22:19 • point
Liam, sorry I didn't see you questions sooner!
The clock detection got broken in recent updates of browsers. (They removed the ability to discover your local IP address that I was using to scan the local net). I need to make a workaround.
I'm glad you got it working! Let me know if you have any other questions.
18923 wrote 08/07/2020 at 23:23 • point
Scoops, thank you for your reply...
FYI,  No action required.
1) All was well for a week until we got a power failure, the clock did not reconnect when power came back. Seems if the router is slower to come up the NodeMCU web server does not restart/connect or try to reconnect later. OR it may be related to (2) below.
2) The barn is run off a TP Link Power extender and I am finding that when I unplug the Clock and plug it back in, it's a hit or miss with the Clock starting properly in the barn, the TP Link is slow due to distance. If the clock is in the house it starts up fine every time.
3) One more thing, since I am only using one bell, I modified the code slightly to run off an ESP-01 relay module. The relay controls the bell instead of using the ULN2003.
Thanks again
Liam in Canada
Magnus Lindhé wrote 01/11/2020 at 10:37 • point
Could you post some images of how you mounted the pipes, to get such a pure tone?
Scoops wrote 01/22/2020 at 08:16 • point
Magnus, at first I temporarily wrapped some twine in a clove hitch around in the tubes at the hanging point and that actually worked pretty well, and the tubes never slipped down. But later I drilled some holes. I will get photos later this week.
Scoops wrote 01/26/2020 at 14:18 • point
Magnus, I added some pictures of the tube mounts.
Magnus Lindhé wrote 01/26/2020 at 15:10 • point
Thanks! I would have thought that the double wire would silence the tubes some more, but apparently not. Nice to get that extra stability!
Charles Pearman wrote 01/08/2020 at 17:41 • point
This rather lovely project has inspired me to resurrect my 82. 87% complete ESP8266 chiming clock. It uses metal platters from 2" and 3.5" HDD (which give a wonderfully sweet tone) and car central locking solenoids (which are a bit bulky and rather noisy). The code here is more feature-rich than mine so will definitely be 'borrowed'!
Chris Knight wrote 01/08/2020 at 18:33 • point
Was thinking the same thing, use platters! (Would be even cooler to use a tile saw to cut the platters to tune them.)
Scoops wrote 01/10/2020 at 04:18 • point
The platters would be more compact, and the old 5" ones have a nice ring, but I'm not sure how you could tune them.
Theses aluminum tubes have a very nice sustain.
Randy Walker wrote 01/08/2020 at 16:55 • point
I must find a use for this!!
Mike Szczys wrote 01/06/2020 at 20:16 • point
Epic use of the HDD parts. Well done!
Dan Maloney wrote 01/03/2020 at 17:05 • point
At first I thought it was "AI" tubes and I wondered how artificial intelligence  came into clock design.
Nice sound. And I like the idea of hard drives for clappers.
Haha those lousy sans-serif fonts.
kristina panos wrote 01/03/2020 at 16:54 • point
What a cool clock!
