Codaic provides an intuitive graphical user interface that gives you direct access to a wide range of hardware and software capabilities available on your iOS device. By leveraging your iOS device instead of dedicated embedded components, you can realize several key benefits:
▸ Cost savings — avoid purchasing components your phone already includes
▸ Time efficiency — focus on implementation with no hardware setup required
▸ Sustainability — reuse existing devices instead of buying new hardware
Consider what is typically required to add an IMU to a project.
With a traditional embedded solution, you must identify a suitable chip, place an order, wait for delivery, study the datasheet, and correctly configure numerous registers. With Cosmic, you can immediately use the built-in IMU of your iOS device. Simply install the app, open your browser, and begin implementation through an easy-to-use graphical interface.
Currently Supported Features
- Hardware
- Accelerometer
- Magnetometer
- Gyroscope
- Vibrator
- GPS
- Torch
- Communication
- HTTP
Oliver Herklotz
Grandeur
Scott Hasse
Sergio Demian Lerner
Thank you for your efforts and for the quick reply. I will be using a Samsung Galaxy S9+
