update
06/18/2020 at 20:31 • 0 commentsA small update for #LabDroid is on the way.
I added three new sensors: Pressure, Relative Humidity and Temperature!
Note: If your device doesn't support one of the sensors you will never receive any data from the Data channel.
update
06/16/2020 at 21:10 • 0 commentsSmall update is on the way to your devices.
Improved the performance, design and fixed some issues with the examples.
Update
06/13/2020 at 11:43 • 0 commentsNice 60+ followers. Thanks <3
I was quite busy the last weeks with my normal job. We installed a robot in Luzern. :)I'm still fine tuning the new IDE design for the next release. It will include a basic editor that enable you to write your own interfaces with HTML/CSS/JS.
FYI
05/30/2020 at 10:14 • 0 commentsFound a bug in the SensorFusion UI. It's not able to connect unless your phone IP is 192.168.1.11. Sorry for that. :X
Will use the long weekend to add one missing part to LabDroid. Stay tuned!p.s. Looks like a have another bug related to Android 9.0. Because I'm using a Android 10.0 device and the emulator with 9.0 works fine for me it would be lovely if you can submit the full crash report. Thanks for your help.
Documentation Uodate
05/27/2020 at 19:58 • 0 comments -
20200524.0
05/24/2020 at 14:23 • 0 commentsNext version is published including the new Sensor Fusion example.
Update
05/23/2020 at 20:35 • 0 commentsToday I redesigned the project create dialog a little bit and worked on a simple sensor fusion (okay lets say drift compensation) example.
Hope to release tomorrow!
20200520.0
05/20/2020 at 19:24 • 0 commentsNext update is published!
New features since the last post:- support for files (store your data in any way you need them)
- you can now show a black screen instead of the log to save energy
20200510.0
05/11/2020 at 20:27 • 0 commentsThe new version is released!
The inbuild examples are updated and can be used to understand the new structure.
Note: You need now to activate the components you would like to use (eg. GPS, Accelerometer, ...). This can be done via an auto start configuration or during runtime (eg. GPS.Status).
https://play.google.com/store/apps/details?id=io.github.herrherklotz.chameleon
FYI
03/14/2020 at 10:23 • 0 commentsWorking on a redesign to make LabDroid easier to use.
Hope to release soon. Stay tuned!
