Open Source?!
01/31/2021 at 11:00 • 0 commentsAt one point LabDroid will use many functionalities your android devices offers. This will lead to more serious questions about datasecurity.
To avoid insecurities I will publish the backend as Open Source. My current plan includes to finish this step in Summer 2021.
Stay tuned!
Update blocked
01/30/2021 at 15:56 • 0 commentsMy last update was blocked by Google because of some issues I understand and some who are fucking stupid. :(
Prominent disclosure not found
Your app must display a prominent disclosure through a pop-up alert before your app’s location runtime permission. [..]
Include at least the following sentence, adapted to include all the relevant features requesting access to location in the background in the app that are readily visible to the user: “This app collects location data to enable ["feature"], ["feature"], & ["feature"] even when the app is closed or not in use.”Somehow I'm now forced to explain one of the biggest tech company in the world the use case of an IDE.
20210123.0
01/24/2021 at 09:45 • 0 commentsFinally I could implement the last missing part of my concept for LabDroid: Variables!
Now it's possible to store information and reuse them on another run of the same project.
For example: If you would make a RC controlled car which is equipped with an Android phone running LabDroid, you could store/accumulate usage data like driven distance or used energie.
How to use
1. Step: Add the variables you need. You can choose between number or string as a dataytype. The String datatype can also be used to store JSON serialized objects.
2. Step: Connect them to your script.
3. Step: Use them in your script. :)
4. Step: And here is the result!
Note: The variables will be saved if the project is finished. During runtime they stay in the memory to provide the best possible performance.
Beside of another feature I will add this year, I want to focus more on making the application stable, improve UX and add more components.
WIsh you a nice sunday! -
20210109.0
01/09/2021 at 11:53 • 0 commentsI just published the first update this year.
It improves the input port of script nodes. It's now possible to get stream based ($receive()) and static ($poll) data.
For example you can $poll() the string which describes the battery technology of your phone.
20200926.0
09/26/2020 at 10:16 • 0 commentsJust published a new version today. This update includes the imorved front-end editor.
To be honest this is the worst tested update yet. I just needed some good feelings from pressing the release button. The last weeks at work have been quite exhausting for me.
I will now focus more on stability and hopefully update in a 1-2 week rhythm.
I'm still on it ...
08/28/2020 at 16:23 • 0 commentsRecently I didn't have time to work on LabDroid but it looks quite promising that it will change soon! In the next few weeks I should be able to finally release the big front-end update that allows you to create more complex graphical user interfaces for your projects.
In the meanwhile I updated the website, hope you like it.
Update
07/01/2020 at 20:49 • 0 commentsOkay I will put the source on GitHub: https://github.com/HerrHerklotz/LabDroid
If I have time I will do a YouTube Video to introduce new users to LabDroid. I think the dice will be a good project for this. :)) -
A dice with LabDroid
06/30/2020 at 21:17 • 0 commentsToday I did a simple dice with LabDroid:
function getRandom(max) { return 1+Math.floor(Math.random() * Math.floor(max)) } let force = 0.0 let rolled = "" while(true) { const accel = $in(0) force += Math.abs(accel.x) + Math.abs(accel.y) if (force > 100.0) // Keep the dice on the floor force = 90.0 else if (force > 30.0) { force *= 0.6 rolled += getRandom(6) + " " } else if (force > 10) // The dice wiggles out force *= 0.6 else { if (rolled.length > 0) { $log(rolled + "*" + getRandom(6) + "*") rolled = "" $sleep(1000) // Give the dice some time to cool down } force = 0.0 } }
Still thinking about how I could share some example projects. Hackaday, Instructable, YouTube or Github?! :/
Any other recommendations? :D -
20200628.1
06/28/2020 at 21:33 • 0 commentsNew version is on the way.
This time I focused on the UX : more shortcuts & feedback (toasts)ps. just found a small mistake: To delete a Node you also need to press CTRL + D (not DEL)
Thx for 100 followers :))
06/21/2020 at 08:58 • 0 commentsHere is a quick and dirty teaser for my next goal: Building a RC car with LabDroid.
https://www.youtube.com/watch?v=DczLu7f4gTY
First step: Using the phone as a controller (GUI & rotation sensor)LabDroid -> BT -> Arduino
Second step: Place the phone on the car and use the sensors to track the movements.
Tablet -> WIFI -> LabDroid -> USB -> Arduino
