New Tutorial for Portenta H7
08/30/2022 at 08:14 • 0 commentsA new tutorial for MBUS Shield and Portenta H7 is available on arduino.cc
https://create.arduino.cc/projecthub/hwhardsoft/smartmetering-with-portenta-h7-237239
MicroPython sources on Github
08/27/2022 at 08:58 • 0 commentsNew sources for MicroPython (tested with Arduino Portenta and Raspberry Pi Pico) available at github.
https://github.com/HWHardsoft/micropyMeterBus
Use M-BUS Shield on the Raspberry Pi
07/21/2022 at 14:03 • 0 commentsYou can also use the M-BUS Shield for the Arduino MKR with the Raspberry Pi using a PiMKRHAT
New code example on GITHUB
09/15/2021 at 15:18 • 0 commentsA new code example of a basic M-BUS master to readout M-BUS slaves directly with the Arduino MKR is available on GITHUB.
Code example for M-BUS Repeater
01/19/2020 at 13:52 • 0 commentsThe first code example for a simple M-Bus adaptor is availabe on GITHUB
https://github.com/HWHardsoft/Arduino-MBUS-repeater
